AGReverse
Hello,
I have several Tab Pro's that are all having the same problem. I have charged the devices to 100% then when it sits for a few days it will not turn back on. I have plugged it back in and it show 0%.
This is what i have done to try and find the issue...
1. I have reset all cables
2.Tried different batteries (USED)
3.Re-Rom with ODIN and Factory reset
4.Checked the pins on battery terminal for bad solder contacts
5.Waiting on new batteries
Now the interesting part. I charged 2 devices to 100% then disconnected the battery from the Logic board so I could check to see if the battery is discharging on its own. After 3 days I reconnected the battery terminal and tried to turn it back on. They will not power on, then I plug in the charger and battery icon shows up with 100% and then I'm able to turn it back on. Any ideas what the issues with these are I have about 8 of them all doing the same thing?
Thank you,
Thank you,
