Just came over to the S5 from the Razr HD. Does anyone know of an app that does what he Smart Actions app on motorola phones does?
I found a couple crappy ones in the app store but they only allow for one trigger and one action. For instance with the motorola app you can create a profile called Sleep. The triggers could be a start and an end time as well as specific days of the week and the actions could be something like silence volume and turn on wifi
all the apps I found only let you put in a start OR an end time and only volume silence as an example
