I can confirm that Smart Switch definitely connects and works with a Mate 10 and a Galaxy S7 via WiFi. For the S10, have you got the latest version of Smart Switch? Is your Mate 10 running 8.0 Oreo or 9.0 Pie? Also the WiFi, is it a public one? Because some public WiFi may block direct data packets between devices, that Smart Switch requires
It's Android 8.0 Oreo on Mate 10. And yes, it is public wifi hotspot. I will try at home and see if there is any difference. thanks
It is public wifi hotspot,you'd better not try it,to avoid computer viruses,disconnect the wi-fi and bluetooth connections and turn them on again.It's Android 8.0 Oreo on Mate 10. And yes, it is public wifi hotspot. I will try at home and see if there is any difference. thanks
You can certainly use Smart Switch with WiFi, because I've done it before with a Mate 10 and Galaxy S7. But using my own private WiFi at home.It is public wifi hotspot,you'd better not try it,to avoid computer viruses,disconnect the wi-fi and bluetooth connections and turn them on again.
It is best if you try connecting the two phones to computer with USB cable,so that everything on Mate 10 can be transfered.
