kezetri
I recently discovered that my S7 edge has a wierd smell stuck to it after water had gotten stuck between the back of the phone and the 2 layers of the case that i use (otterbox case).
One layer of the case is rubber which has the smell on it (like a moldy or mossy smell, hard to describe). I soaked the case parts in isopropyl alcohol for about an hour and the plastic part of the case was clean but the rubber still had the smell. I also tried cleaning my phone but the stench seems to be stuck on it aswell despite using the isopropyl and also
soap. is there anything else i could do to try and remove it?
