SMS text box too small - can it be resized?
Hi,
I have bought the superb Better keyboard 3 which lets me resize the T9 keypad buttons to make them smaller.
Only problem is that the text input box for SMS on the stock app is just 1 line and too small. You cant get a half decent view of what you are typipng without scrolling through.
Is there any way to resize this to see more as the screen does now have the space.
Cheers all.
(PS) I wont use handcent because if fails to attach audio properly.
I too would like some app that increases the size of the text input box for SMS on the stock app.
I am not interested in viewing the previous message 'bubbles' in a thread that appear above the text input box. I think that is a total waste of screen space.
All that I want to see when I am inputting a message is what I am writing. In the stock app you can only see three or four words of what you are writing. I would like the whole screen above the keypad to be the text input box, and also have the ability to increase the size of the input text in that box.
