SNesoid problems
Baggy
I've tried using this on my Racer but the controls don't work right i.e. can't run and jump could it be just the screen on this zte racer i.e. resistive.
And also due to its android having no UI sense could i use a bluetooth pad????
You would need multitouch to use on-screen controls properly. Since its resistive, I doubt it has multitouch, or works very well.
If you have a Wii controller that just happens to be laying around, you can use that as a gamepad. I'm sure many other Bluetooth controllers would work as well.
Thats what I thought the screen just isn't supported. I do have that wii controller but I don't want to pay for the software using my card and the market doesn't put it on your phone bill or else I would.
is there an other SNES emulator for Android that works????
