So dissapointed in Huawei Y9 Pro
Actually, I am so disappointed with my new Android device. The specification described it as excellent. But it has issues with the fingerprint. Couldn't apply themes because it does not compatible (I guess) now I discovered that the front camera quality is out of questions. Samsung Z1 has a better camera. The quality is really low and I can see the pixels in the picture. I don't know what to do with it.
Specifications tell you nothing about quality (something you should always remember). But seeing pixels in an image seems very odd: what is the resolution of the images? You might produce artifacts if the resolution is comparable to the screen and you make it fill the screen when viewing, but if so that's because of your trying to rescale it rather than the image itself. But otherwise the only reason you'd see individual pixels would be if the settings are off (you've got it set to a low resolution) or you can see the pixels on your display generally (which seems sligtly unlikely for a display of that size and resolution, especially since it's an IPS and so will have an RGB sub-pixel structure rather than the lower-resolution structures used by OLED displays).
Check your settings, and if it is using its full resolution could you upload a sample?
What themes are incompatible, ones from the Huawei EMUI Theme Store, or some other third-party ones?
