Software Update/WiFi problem
Scotty66
I have a problem that started a few days ago.
While i was at work and out of range from my home WiFi I checked for software updates on my phone. None were found.
However since then,every 5 mins while I am out of my own WiFi range the phone tells me that a software update has failed due to no WiFi connection.
When I am then in range of my WiFi,the message stops popping up but there are no updates to be found? Also the phone sometimes cannot connect to server when I press software update button.
As soon as the WiFi is turned off or I go out of range the phone seems to search for an update but fails and I receive a notification.
Any ideas or help would be much appreciated.
As soon as I click software update the phone does a search for any available downloads. No other options are available. The only option I have of turning off only update via wi-fi is on the play store.
No probs anyway,today the problem did not happen so it seems to have mysteriously fixed itself :D
