WhiteRau
got new system. godawful Windows 10. all drives moved over. same login/pass. drives are visible but now are inaccessible. a dialog just pops up at the bottom: 0xC0000205.
it should be noted the User folder works without issue, but the other drives pop the 'error'.
what the hell is this and how do i fix it? everything was working fine in Win 7 Pro. can't find support for this application anywhere. and i'm kinda pissed about that because i paid for it.
any help would be appreciated. this is a key piece of functionality in our workflow.
thanks all.
thanks all.
