Palm2droid
I've had my phone for just over 2 years and its starting to fritz..
The fingerprint scanner's coating started to peel. I had to delete and re-scan my print to get it functional again, but in the end what I did is gently rub it with a cotton cloth [ handkerchief ] and removed the remaining coating. It now works reliably again. What a royal PIA this was until fixed.
I had a few random USB charging port "moisture detected" issues. I followed each of the suggestions below that I found around the intertubes, and I believe that the first time it corrected by accident, while the second time I found an actual solution. I believe this is being cause by looseness/damage to the male charge pin in the charging port causing a short that triggers the moisture sensor alert.
TRIED but did not work:
Blasting with air
Putting in AC vent
Different charging cables
Multiple restarts
Apps / Show System Apps / USB Settings / Storage / Clear cache
Apps / Show System Apps / Android system / Force stop
Removing 'recently installed or updated' Apps
Note: Would not charge even with phone powered off.
Had to get a wireless charger as phone went completely dead
WORKED:
Inserted probe under bottom edge of male connector w/in charging access port on phone and gently pried up ever so very slightly. Accepted charge immediately after doing this.
A better design for the charger port would be to have no free play up/down but instead a snug fit of the cable into the port.
I hope this helps others.
Blasting with air
Putting in AC vent
Multiple restarts
WORKED:
