Hello LV426. Here is the log. and I ment Gradle
2019-01-05 12:27:25,710 [ain Thread] INFO - #com.intellij.idea.Main - ------------------------------------------------------ IDE STARTED ------------------------------------------------------
2019-01-05 12:27:26,210 [e-1136-b06] INFO - #com.intellij.idea.Main - IDE: Android Studio (build #AI-181.5540.7.32.5056338, 08 Oct 2018 17:26)
2019-01-05 12:27:26,210 [e-1136-b06] INFO - #com.intellij.idea.Main - OS: Windows 10 (10.0, amd64)
2019-01-05 12:27:26,210 [e-1136-b06] INFO - #com.intellij.idea.Main - JRE: 1.8.0_152-release-1136-b06 (JetBrains s.r.o)
2019-01-05 12:27:26,210 [e-1136-b06] INFO - #com.intellij.idea.Main - JVM: 25.152-b06 (OpenJDK 64-Bit Server VM)
2019-01-05 12:27:26,226 [e-1136-b06] INFO - #com.intellij.idea.Main - JVM Args: -Xms256m -Xmx1280m -XX:ReservedCodeCacheSize=240m -XX:+UseConcMarkSweepGC -XX:SoftRefLRUPolicyMSPerMB=50 -Dsun.io.useCanonCaches=false -Djava.net.preferIPv4Stack=true -Djna.nosys=true -Djna.boot.library.path= -da -Djb.vmOptionsFile=C:\Program Files\Android\Android Studio\bin\studio64.exe.vmoptions -Xbootclasspath/a:C:\Program Files\Android\Android Studio\lib\boot.jar -Didea.platform.prefix=AndroidStudio -Didea.jre.check=true -Dide.native.launcher=true -Didea.paths.selector=AndroidStudio3.2 -XX:ErrorFile=C:\Users\Gragon IV\java_error_in_studio_%p.log -XX:HeapDumpPath=C:\Users\Gragon IV\java_error_in_studio.hprof
2019-01-05 12:27:26,226 [e-1136-b06] INFO - #com.intellij.idea.Main - ext: C:\Program Files\Android\Android Studio\jre\jre\lib\ext: [access-bridge-64.jar, cldrdata.jar, dnsns.jar, jaccess.jar, localedata.jar, meta-index, nashorn.jar, sunec.jar, sunjce_provider.jar, sunmscapi.jar, sunpkcs11.jar, zipfs.jar]
2019-01-05 12:27:26,226 [e-1136-b06] INFO - #com.intellij.idea.Main - JNU charset: Cp1252
2019-01-05 12:27:26,288 [e-1136-b06] INFO - #com.intellij.idea.Main - JNA library (64-bit) loaded in 62 ms
2019-01-05 12:27:26,304 [e-1136-b06] INFO - penapi.util.io.win32.IdeaWin32 - Native filesystem for Windows is operational
2019-01-05 12:27:26,647 [e-1136-b06] INFO - #com.intellij.util.ui.JBUI - User scale factor: 1.0
2019-01-05 12:27:26,647 [e-1136-b06] INFO - #com.intellij.util.ui.JBUI - System scale factor: 1.0 (JRE-managed HiDPI)
2019-01-05 12:27:35,664 [entQueue-0] INFO - .intellij.idea.IdeaApplication - CPU cores: 4; ForkJoinPool.commonPool: java.util.concurrent.ForkJoinPool@6af6dd35[Running, parallelism = 3, size = 0, active = 0, running = 0, steals = 0, tasks = 0, submissions = 0]; factory: com.intellij.concurrency.IdeaForkJoinWorkerThreadFactory@134c813b
2019-01-05 12:27:36,711 [entQueue-0] INFO - llij.ide.plugins.PluginManager - Cannot find optional descriptor duplicates-groovy.xml
2019-01-05 12:27:37,305 [entQueue-0] INFO - llij.ide.plugins.PluginManager - 38 plugins initialized in 1282 ms
2019-01-05 12:27:37,305 [entQueue-0] INFO - llij.ide.plugins.PluginManager - Loaded bundled plugins: Android APK Support (1.0), Android Games (1.0), Android NDK Support (1.0), Android Support (10.3.2.1), App Links Assistant (0.1), CVS Integration (11), Copyright (8.1), Coverage (181.5540.7.32.5056338), EditorConfig (181.5540.7.32.5056338), Firebase App Indexing (0.1), Firebase Services (0.1), Firebase Testing (1.0), Git Integration (8.1), GitHub (181.5540.7.32.5056338), Google Cloud Tools Core (0.2.8), Google Cloud Tools For Android Studio (0.2.8), Google Developers Samples (0.3.1), Google Login (1.0), Google Services (0.1), Gradle (181.5540.7.32.5056338), Groovy (9.0), I18n for Java (181.5540.7.32.5056338), IDEA CORE (181.5540.7.32.5056338), IntelliLang (8.0), JUnit (1.0), Java Bytecode Decompiler (181.5540.7.32.5056338), Java Stream Debugger (181.5540.7.32.5056338), Kotlin (1.2.71-release-Studio3.2-1), Mercurial Integration (10.0), Properties Support (181.5540.7.32.5056338), Settings Repository (181.5540.7.32.5056338), Smali Support (1.0), Subversion Integration (1.1), Task Management (1.0), Terminal (0.1), Test Recorder (1.0), TestNG-J (8.0), YAML (181.5540.7.32.5056338)
2019-01-05 12:27:39,805 [entQueue-0] INFO - ellij.vfs.persistent.FSRecords - Marking VFS as corrupted: 'C:\Users\Gragon IV\.AndroidStudio3.2\system\caches\names.dat' does not exist
2019-01-05 12:27:39,805 [entQueue-0] INFO - ellij.util.io.PagedFileStorage - lower=100; upper=500; buffer=10; max=1226
2019-01-05 12:27:39,915 [entQueue-0] INFO - pl.local.NativeFileWatcherImpl - Starting file watcher: C:\Program Files\Android\Android Studio\bin\fsnotifier64.exe
2019-01-05 12:27:39,961 [entQueue-0] INFO - pl.local.NativeFileWatcherImpl - Native file watcher is operational.
2019-01-05 12:27:41,196 [e-1136-b06] WARN - nSystem.impl.ActionManagerImpl - keymap "Xcode" not found [Plugin: Git4Idea]
2019-01-05 12:27:41,243 [e-1136-b06] WARN - nSystem.impl.ActionManagerImpl - keymap "Xcode" not found [Plugin: hg4idea]
2019-01-05 12:27:41,274 [e-1136-b06] WARN - nSystem.impl.ActionManagerImpl - keymap "Xcode" not found [Plugin: com.android.tools.ndk]
2019-01-05 12:27:41,321 [e-1136-b06] INFO - .history.utils.LocalHistoryLog - local history version mismatch (was: 0, expected: 6), rebuilding...
2019-01-05 12:27:41,321 [e-1136-b06] INFO - .history.utils.LocalHistoryLog - FS has been rebuild, rebuilding local history...
2019-01-05 12:27:41,797 [d thread 1] INFO - .openapi.application.Preloader - Finished preloading com.intellij.ide.ui.OptionsTopHitProvider$Activity@45561312
2019-01-05 12:27:42,388 [e-1136-b06] INFO - til.net.ssl.CertificateManager - Default SSL context initialized
2019-01-05 12:27:42,503 [d thread 3] INFO - rains.ide.BuiltInServerManager - built-in server started, port 63342
2019-01-05 12:27:42,653 [e-1136-b06] INFO - gs.impl.UpdateCheckerComponent - channel: release
2019-01-05 12:27:44,594 [e-1136-b06] INFO - il.indexing.FileBasedIndexImpl - Index exts enumerated:1715, number of extensions:35
2019-01-05 12:27:44,607 [e-1136-b06] INFO - il.indexing.FileBasedIndexImpl - Index scheduled:20
2019-01-05 12:27:45,073 [e-1136-b06] INFO - tellij.psi.stubs.StubIndexImpl - All stub exts enumerated:446, number of extensions:50
2019-01-05 12:27:45,073 [e-1136-b06] INFO - tellij.psi.stubs.StubIndexImpl - stub exts update scheduled:13
2019-01-05 12:27:47,050 [d thread 3] INFO - ij.psi.stubs.StubUpdatingIndex - Following new file types will be indexed:HTML,Properties,CLASS,GDBCommands,LLDBCommands,JAVA,Groovy,XML,KJSM,kotlin_builtins,Kotlin
2019-01-05 12:27:47,984 [e-1136-b06] INFO - ellij.project.impl.ProjectImpl - 21 project components initialized in 1737 ms
2019-01-05 12:27:49,099 [e-1136-b06] INFO - com.intellij.ide.ui.UISettings - Loaded: fontSize=12, fontScale=1.0; restored: fontSize=12, fontScale=1.0
2019-01-05 12:27:50,017 [d thread 3] INFO - pl$FileIndexDataInitialization - Initialization done:5398
2019-01-05 12:27:51,055 [d thread 3] INFO - exImpl$StubIndexInitialization - Initialization done:1038
2019-01-05 12:27:51,541 [e-1136-b06] INFO - plication.impl.ApplicationImpl - 88 application components initialized in 15518ms
2019-01-05 12:27:51,573 [e-1136-b06] INFO - .intellij.idea.IdeaApplication - App initialization took 27932 ms
2019-01-05 12:27:52,175 [d thread 3] INFO - ateSettings.impl.UpdateChecker - dl.google.com
java.net.UnknownHostException: dl.google.com
at java.net.AbstractPlainSocketImpl.connect(AbstractPlainSocketImpl.java:184)
at java.net.PlainSocketImpl.connect(PlainSocketImpl.java:172)
at java.net.SocksSocketImpl.connect(SocksSocketImpl.java:392)
at java.net.Socket.connect(Socket.java:589)
at sun.security.ssl.SSLSocketImpl.connect(SSLSocketImpl.java:673)
at sun.net.NetworkClient.doConnect(NetworkClient.java:175)
at sun.net.
www.http.HttpClient.openServer(HttpClient.java:432)
at sun.net.
www.http.HttpClient.openServer(HttpClient.java:527)
at sun.net.
www.protocol.https.HttpsClient.<init>(HttpsClient.java:264)
at sun.net.
www.protocol.https.HttpsClient.New(HttpsClient.java:367)
at sun.net.
www.protocol.https.AbstractDelegateHttpsURLConnection.getNewHttpClient(AbstractDelegateHttpsURLConnection.java:191)
at sun.net.
www.protocol.http.HttpURLConnection.plainConnect0(HttpURLConnection.java:1181)
at sun.net.
www.protocol.http.HttpURLConnection.plainConnect(HttpURLConnection.java:1032)
at sun.net.
www.protocol.https.AbstractDelegateHttpsURLConnection.connect(AbstractDelegateHttpsURLConnection.java:177)
at sun.net.
www.protocol.http.HttpURLConnection.getInputStream0(HttpURLConnection.java:1546)
at sun.net.
www.protocol.http.HttpURLConnection.getInputStream(HttpURLConnection.java:1474)
at java.net.HttpURLConnection.getResponseCode(HttpURLConnection.java:480)
at sun.net.
www.protocol.https.HttpsURLConnectionImpl.getResponseCode(HttpsURLConnectionImpl.java:338)
at com.intellij.util.io.HttpRequests.openConnection(HttpRequests.java:498)
at com.intellij.util.io.HttpRequests.access$300(HttpRequests.java:49)
at com.intellij.util.io.HttpRequests$RequestImpl.getConnection(HttpRequests.java:278)
at com.intellij.util.io.HttpRequests$RequestImpl.getInputStream(HttpRequests.java:287)
at com.intellij.util.io.HttpRequests$RequestImpl.getReader(HttpRequests.java:305)
at com.intellij.util.io.HttpRequests$RequestImpl.getReader(HttpRequests.java:298)
at com.intellij.openapi.updateSettings.impl.UpdateChecker$checkPlatformUpdate$1.process(UpdateChecker.kt:176)
at com.intellij.openapi.updateSettings.impl.UpdateChecker$checkPlatformUpdate$1.process(UpdateChecker.kt:54)
at com.intellij.util.io.HttpRequests.lambda$doProcess$0(HttpRequests.java:403)
at com.intellij.util.net.ssl.CertificateManager.runWithUntrustedCertificateStrategy(CertificateManager.java:335)
at com.intellij.util.io.HttpRequests.doProcess(HttpRequests.java:403)
at com.intellij.util.io.HttpRequests.process(HttpRequests.java:383)
at com.intellij.util.io.HttpRequests.access$100(HttpRequests.java:49)
at com.intellij.util.io.HttpRequests$RequestBuilderImpl.connect(HttpRequests.java:252)
at com.intellij.openapi.updateSettings.impl.UpdateChecker.checkPlatformUpdate(UpdateChecker.kt:174)
at com.intellij.openapi.updateSettings.impl.UpdateChecker.doUpdateAndShowResult(UpdateChecker.kt:120)
at com.intellij.openapi.updateSettings.impl.UpdateChecker.access$doUpdateAndShowResult(UpdateChecker.kt:54)
at com.intellij.openapi.updateSettings.impl.UpdateChecker$updateAndShowResult$1.run(UpdateChecker.kt:82)
at com.intellij.openapi.application.impl.ApplicationImpl$1.run(ApplicationImpl.java:305)
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511)
at java.util.concurrent.FutureTask.run(FutureTask.java:266)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617)
at java.lang.Thread.run(Thread.java:745)
2019-01-05 12:27:52,175 [d thread 3] INFO - ateSettings.impl.UpdateChecker - Connection failed (dl.google.com). Please check network connection and try again.
2019-01-05 12:27:53,066 [d thread 1] INFO - .openapi.application.Preloader - Finished preloading com.intellij.openapi.actionSystem.impl.ActionPreloader@7abb6989
2019-01-05 12:27:55,019 [d thread 1] INFO - .openapi.application.Preloader - Finished preloading com.intellij.ide.ui.search.SearchableOptionPreloader@5c5c3156
2019-01-05 12:27:55,801 [d thread 1] INFO - .openapi.application.Preloader - Finished preloading com.intellij.codeInsight.completion.CompletionPreloader@6f931aee
2019-01-05 12:27:55,832 [d thread 1] INFO - .openapi.application.Preloader - Finished preloading com.intellij.ide.actions.GotoClassPresentationUpdater@15f34e63
2019-01-05 12:28:06,990 [d thread 1] WARN - ess.util.ProgressIndicatorBase - This progress indicator is indeterminate, this may lead to visual inconsistency. Please call setIndeterminate(false) before you start progress.
2019-01-05 12:28:06,990 [d thread 1] INFO - s.RepoProgressIndicatorAdapter - File C:\Users\Gragon IV\.android\repositories.cfg could not be loaded.
2019-01-05 12:28:06,990 [d thread 1] INFO - s.RepoProgressIndicatorAdapter - Downloading file:/C:/Program%20Files/Android/Android%20Studio/plugins/sdk-updates/offline-repo/offline-repo.xml
2019-01-05 12:28:07,521 [d thread 1] INFO - s.RepoProgressIndicatorAdapter - Downloading
https://dl.google.com/android/repository/addons_list-3.xml
2019-01-05 12:28:07,521 [d thread 1] INFO - s.RepoProgressIndicatorAdapter - IOException:
2019-01-05 12:28:07,521 [d thread 1] INFO - s.RepoProgressIndicatorAdapter - java.io.IOException: Cannot download '
https://dl.google.com/android/repository/addons_list-3.xml': dl.google.com
https://dl.google.com/android/repository/addons_list-2.xml
https://dl.google.com/android/repository/addons_list-2.xml': dl.google.com
https://dl.google.com/android/repository/addons_list-1.xml
2019-01-05 12:28:07,537 [d thread 1] INFO - s.RepoProgressIndicatorAdapter - IOException:
2019-01-05 12:28:07,537 [d thread 1] INFO - s.RepoProgressIndicatorAdapter - java.io.IOException: Cannot download '
https://dl.google.com/android/repository/addons_list-1.xml': dl.google.com
2019-01-05 12:28:07,537 [d thread 1] WARN - s.RepoProgressIndicatorAdapter - Failed to download any source lists!
2019-01-05 12:28:07,537 [d thread 1] INFO - s.RepoProgressIndicatorAdapter - Downloading
https://dl.google.com/android/repository/repository2-1.xml
2019-01-05 12:28:07,537 [d thread 1] WARN - s.RepoProgressIndicatorAdapter - java.io.IOException: Cannot download '
https://dl.google.com/android/repository/repository2-1.xml': dl.google.com
2019-01-05 12:28:07,568 [e-1136-b06] WARN - vdmanager.AvdManagerConnection - No Android SDK Found
2019-01-05 12:28:08,318 [e-1136-b06] INFO - j.ide.ui.OptionsTopHitProvider - 452 ms spent to cache options in application
2019-01-05 12:28:08,318 [e-1136-b06] INFO - rtup.GradleSpecificInitializer - Found Studio home directory at: 'C:\Program Files\Android\Android Studio'
2019-01-05 12:28:08,318 [e-1136-b06] INFO - rtup.GradleSpecificInitializer - Looking for Android SDK at 'C:/Program Files/Android/Android Studio/sdk'
2019-01-05 12:28:08,318 [e-1136-b06] INFO - rtup.GradleSpecificInitializer - Looking for Android SDK at 'C:/Program Files/Android/sdk'
2019-01-05 12:28:08,318 [e-1136-b06] INFO - rtup.GradleSpecificInitializer - Unable to locate SDK within the Android studio installation.
2019-01-05 12:28:08,318 [e-1136-b06] INFO - rtup.GradleSpecificInitializer - Checking if ANDROID_HOME is set: 'ANDROID_HOME' is 'null'
2019-01-05 12:28:08,318 [e-1136-b06] INFO - rtup.GradleSpecificInitializer - Unable to locate last SDK used by Android tools
2019-01-05 12:28:08,318 [e-1136-b06] INFO - .startup.AndroidSdkInitializer - Found Studio home directory at: 'C:\Program Files\Android\Android Studio'
2019-01-05 12:28:08,318 [e-1136-b06] INFO - .startup.AndroidSdkInitializer - Looking for Android SDK at 'C:/Program Files/Android/Android Studio/sdk'
2019-01-05 12:28:08,318 [e-1136-b06] INFO - .startup.AndroidSdkInitializer - Looking for Android SDK at 'C:/Program Files/Android/sdk'
2019-01-05 12:28:08,318 [e-1136-b06] INFO - .startup.AndroidSdkInitializer - Unable to locate SDK within the Android studio installation.
2019-01-05 12:28:08,318 [e-1136-b06] INFO - .startup.AndroidSdkInitializer - Checking if ANDROID_HOME is set: 'ANDROID_HOME' is 'null'
2019-01-05 12:28:08,318 [e-1136-b06] INFO - .startup.AndroidSdkInitializer - Unable to locate last SDK used by Android tools
2019-01-05 12:28:33,009 [e-1136-b06] WARN - til.ui.update.LazyUiDisposable - use application as a parent disposable
2019-01-05 12:28:56,654 [d thread 3] ERROR - ted.ConsolidatedProgressStep$1 - SDK tools directory is missing
com.android.tools.idea.welcome.install.WizardException: SDK tools directory is missing
at com.android.tools.idea.welcome.install.CheckSdkOperation.perform(CheckSdkOperation.java:118)
at com.android.tools.idea.welcome.install.CheckSdkOperation.perform(CheckSdkOperation.java:39)
at com.android.tools.idea.welcome.install.InstallOperation.execute(InstallOperation.java:69)
at com.android.tools.idea.welcome.install.InstallOperation$OperationChain.perform(InstallOperation.java:156)
at com.android.tools.idea.welcome.wizard.deprecated.InstallComponentsPath.runLongOperation(InstallComponentsPath.java:252)
at com.android.tools.idea.welcome.wizard.deprecated.ConsolidatedProgressStep.doLongRunningOperation(ConsolidatedProgressStep.java:78)
at com.android.tools.idea.welcome.wizard.deprecated.ConsolidatedProgressStep.access$000(ConsolidatedProgressStep.java:32)
at com.android.tools.idea.welcome.wizard.deprecated.ConsolidatedProgressStep$1.run(ConsolidatedProgressStep.java:58)
at com.android.tools.idea.welcome.wizard.deprecated.FirstRunWizardHost$LongRunningOperationWrapper.run(FirstRunWizardHost.java:440)
at com.intellij.openapi.progress.impl.CoreProgressManager$TaskRunnable.run(CoreProgressManager.java:750)
at com.intellij.openapi.progress.impl.CoreProgressManager.lambda$runProcess$1(CoreProgressManager.java:157)
at com.intellij.openapi.progress.impl.CoreProgressManager.registerIndicatorAndRun(CoreProgressManager.java:580)
at com.intellij.openapi.progress.impl.CoreProgressManager.executeProcessUnderProgress(CoreProgressManager.java:525)
at com.intellij.openapi.progress.impl.ProgressManagerImpl.executeProcessUnderProgress(ProgressManagerImpl.java:85)
at com.intellij.openapi.progress.impl.CoreProgressManager.runProcess(CoreProgressManager.java:144)
at com.intellij.openapi.progress.impl.CoreProgressManager$4.run(CoreProgressManager.java:395)
2019-01-05 12:28:56,654 [d thread 3] ERROR - ted.ConsolidatedProgressStep$1 - Android Studio 3.2.1 Build #AI-181.5540.7.32.5056338
2019-01-05 12:28:56,654 [d thread 3] ERROR - ted.ConsolidatedProgressStep$1 - JDK: 1.8.0_152-release
2019-01-05 12:28:56,654 [d thread 3] ERROR - ted.ConsolidatedProgressStep$1 - VM: OpenJDK 64-Bit Server VM
2019-01-05 12:28:56,654 [d thread 3] ERROR - ted.ConsolidatedProgressStep$1 - Vendor: JetBrains s.r.o
2019-01-05 12:28:56,654 [d thread 3] ERROR - ted.ConsolidatedProgressStep$1 - OS: Windows 10
2019-01-05 12:28:56,654 [d thread 3] ERROR - ted.ConsolidatedProgressStep$1 - Last Action:
2019-01-05 12:28:59,436 [e-1136-b06] INFO - rd.FirstRunWizardFrameProvider - Overriding welcome frame to be resizable
2019-01-05 12:29:07,546 [e-1136-b06] WARN - ConfigurableExtensionPointUtil - use other group instead of unexpected one: reference.settingsdialog.project.gradle
2019-01-05 12:29:08,437 [d thread 3] INFO - s.RepoProgressIndicatorAdapter - Downloading file:/C:/Program%20Files/Android/Android%20Studio/plugins/sdk-updates/offline-repo/offline-repo.xml
2019-01-05 12:29:08,437 [d thread 1] INFO - er.configure.SourcesTableModel - Downloading
2019-01-05 12:29:08,452 [d thread 1] INFO - er.configure.SourcesTableModel - IOException:
2019-01-05 12:29:08,452 [d thread 1] INFO - er.configure.SourcesTableModel - java.io.IOException: Cannot download '
2019-01-05 12:29:08,452 [d thread 1] INFO - er.configure.SourcesTableModel - Downloading
2019-01-05 12:29:08,452 [d thread 1] WARN - er.configure.SourcesTableModel - Failed to download any source lists!
2019-01-05 12:29:08,452 [d thread 1] INFO - er.configure.SourcesTableModel - File C:\Users\Gragon IV\.android\repositories.cfg could not be loaded.
2019-01-05 12:29:08,499 [d thread 3] INFO - s.RepoProgressIndicatorAdapter - Downloading
2019-01-05 12:29:08,499 [d thread 3] INFO - s.RepoProgressIndicatorAdapter - IOException:
2019-01-05 12:29:08,499 [d thread 3] INFO - s.RepoProgressIndicatorAdapter - java.io.IOException: Cannot download '
2019-01-05 12:29:08,499 [d thread 3] WARN - s.RepoProgressIndicatorAdapter - Failed to download any source lists!
2019-01-05 12:29:08,499 [d thread 3] WARN - s.RepoProgressIndicatorAdapter - java.io.IOException: Cannot download '
2019-01-05 12:29:08,562 [d thread 1] INFO - s.RepoProgressIndicatorAdapter - Downloading file:/C:/Program%20Files/Android/Android%20Studio/plugins/sdk-updates/offline-repo/offline-repo.xml
2019-01-05 12:29:08,593 [d thread 1] INFO - s.RepoProgressIndicatorAdapter - Downloading
2019-01-05 12:29:08,593 [d thread 1] INFO - s.RepoProgressIndicatorAdapter - IOException:
2019-01-05 12:29:08,593 [d thread 1] INFO - s.RepoProgressIndicatorAdapter - java.io.IOException: Cannot download '
2019-01-05 12:29:08,593 [d thread 1] WARN - s.RepoProgressIndicatorAdapter - Failed to download any source lists!
2019-01-05 12:29:08,593 [d thread 1] WARN - s.RepoProgressIndicatorAdapter - java.io.IOException: Cannot download '
2019-01-05 12:32:54,268 [wn tracker] INFO - il.indexing.FileBasedIndexImpl - START INDEX SHUTDOWN
2019-01-05 16:33:39,061 [ain Thread] INFO - #com.intellij.idea.Main - ------------------------------------------------------ IDE STARTED ------------------------------------------------------
2019-01-05 16:33:39,811 [e-1136-b06] INFO - #com.intellij.idea.Main - IDE: Android Studio (build #AI-181.5540.7.32.5056338, 08 Oct 2018 17:39)
2019-01-05 16:33:39,811 [e-1136-b06] INFO - #com.intellij.idea.Main - OS: Windows 10 (10.0, amd64)
2019-01-05 16:33:39,811 [e-1136-b06] INFO - #com.intellij.idea.Main - JRE: 1.8.0_152-release-1136-b06 (JetBrains s.r.o)
2019-01-05 16:33:39,811 [e-1136-b06] INFO - #com.intellij.idea.Main - JVM: 25.152-b06 (OpenJDK 64-Bit Server VM)
2019-01-05 16:33:39,843 [e-1136-b06] INFO - #com.intellij.idea.Main - JVM Args: -Xms256m -Xmx1280m -XX:ReservedCodeCacheSize=240m -XX:+UseConcMarkSweepGC -XX:SoftRefLRUPolicyMSPerMB=50 -Dsun.io.useCanonCaches=false -Djava.net.preferIPv4Stack=true -Djna.nosys=true -Djna.boot.library.path= -da -Djb.vmOptionsFile=C:\Program Files\Android\Android Studio\bin\studio64.exe.vmoptions -Xbootclasspath/a:C:\Program Files\Android\Android Studio\lib\boot.jar -Didea.platform.prefix=AndroidStudio -Didea.jre.check=true -Dide.native.launcher=true -Didea.paths.selector=AndroidStudio3.2 -XX:ErrorFile=C:\Users\Gragon IV\java_error_in_studio_%p.log -XX:HeapDumpPath=C:\Users\Gragon IV\java_error_in_studio.hprof
2019-01-05 16:33:39,843 [e-1136-b06] INFO - #com.intellij.idea.Main - ext: C:\Program Files\Android\Android Studio\jre\jre\lib\ext: [access-bridge-64.jar, cldrdata.jar, dnsns.jar, jaccess.jar, localedata.jar, meta-index, nashorn.jar, sunec.jar, sunjce_provider.jar, sunmscapi.jar, sunpkcs11.jar, zipfs.jar]
2019-01-05 16:33:39,843 [e-1136-b06] INFO - #com.intellij.idea.Main - JNU charset: Cp1252
2019-01-05 16:33:40,061 [e-1136-b06] INFO - #com.intellij.idea.Main - JNA library (64-bit) loaded in 156 ms
2019-01-05 16:33:40,108 [e-1136-b06] INFO - penapi.util.io.win32.IdeaWin32 - Native filesystem for Windows is operational
2019-01-05 16:33:40,499 [e-1136-b06] INFO - #com.intellij.util.ui.JBUI - User scale factor: 1.0
2019-01-05 16:33:40,499 [e-1136-b06] INFO - #com.intellij.util.ui.JBUI - System scale factor: 1.0 (JRE-managed HiDPI)
2019-01-05 16:33:45,890 [entQueue-0] INFO - .intellij.idea.IdeaApplication - CPU cores: 4; ForkJoinPool.commonPool: java.util.concurrent.ForkJoinPool@da53df6[Running, parallelism = 3, size = 0, active = 0, running = 0, steals = 0, tasks = 0, submissions = 0]; factory: com.intellij.concurrency.IdeaForkJoinWorkerThreadFactory@24036bfc
2019-01-05 16:33:50,249 [entQueue-0] INFO - llij.ide.plugins.PluginManager - Cannot find optional descriptor duplicates-groovy.xml
2019-01-05 16:33:51,640 [entQueue-0] INFO - llij.ide.plugins.PluginManager - 38 plugins initialized in 3375 ms
2019-01-05 16:33:51,640 [entQueue-0] INFO - llij.ide.plugins.PluginManager - Loaded bundled plugins: Android APK Support (1.0), Android Games (1.0), Android NDK Support (1.0), Android Support (10.3.2.1), App Links Assistant (0.1), CVS Integration (11), Copyright (8.1), Coverage (181.5540.7.32.5056338), EditorConfig (181.5540.7.32.5056338), Firebase App Indexing (0.1), Firebase Services (0.1), Firebase Testing (1.0), Git Integration (8.1), GitHub (181.5540.7.32.5056338), Google Cloud Tools Core (0.2.8), Google Cloud Tools For Android Studio (0.2.8), Google Developers Samples (0.3.1), Google Login (1.0), Google Services (0.1), Gradle (181.5540.7.32.5056338), Groovy (9.0), I18n for Java (181.5540.7.32.5056338), IDEA CORE (181.5540.7.32.5056338), IntelliLang (8.0), JUnit (1.0), Java Bytecode Decompiler (181.5540.7.32.5056338), Java Stream Debugger (181.5540.7.32.5056338), Mercurial Integration (10.0), Properties Support (181.5540.7.32.5056338), Settings Repository (181.5540.7.32.5056338), Smali Support (1.0), Subversion Integration (1.1), Task Management (1.0), Terminal (0.1), Test Recorder (1.0), TestNG-J (8.0), YAML (181.5540.7.32.5056338)
2019-01-05 16:33:51,640 [entQueue-0] INFO - llij.ide.plugins.PluginManager - Loaded custom plugins: Kotlin (1.3.11-release-Studio3.2-1)
2019-01-05 16:34:02,109 [entQueue-0] INFO - ellij.util.io.PagedFileStorage - lower=100; upper=500; buffer=10; max=1226
2019-01-05 16:34:02,813 [entQueue-0] INFO - pl.local.NativeFileWatcherImpl - Starting file watcher: C:\Program Files\Android\Android Studio\bin\fsnotifier64.exe
2019-01-05 16:34:03,031 [entQueue-0] INFO - pl.local.NativeFileWatcherImpl - Native file watcher is operational.
2019-01-05 16:34:05,750 [e-1136-b06] INFO - com.intellij.ide.ui.UISettings - Loaded: fontSize=12, fontScale=0.0; restored: fontSize=12, fontScale=1.0
2019-01-05 16:34:06,266 [e-1136-b06] WARN - nSystem.impl.ActionManagerImpl - keymap "Xcode" not found [Plugin: Git4Idea]
2019-01-05 16:34:06,500 [e-1136-b06] WARN - nSystem.impl.ActionManagerImpl - keymap "Xcode" not found [Plugin: hg4idea]
2019-01-05 16:34:06,891 [e-1136-b06] WARN - nSystem.impl.ActionManagerImpl - keymap "Xcode" not found [Plugin: com.android.tools.ndk]
2019-01-05 16:34:06,906 [e-1136-b06] WARN - nSystem.impl.ActionManagerImpl - keymap "Xcode" not found [Plugin: com.android.tools.ndk]
2019-01-05 16:34:07,939 [d thread 1] INFO - .openapi.application.Preloader - Finished preloading com.intellij.ide.ui.OptionsTopHitProvider$Activity@997ca2
2019-01-05 16:34:08,947 [e-1136-b06] INFO - til.net.ssl.CertificateManager - Default SSL context initialized
2019-01-05 16:34:09,194 [d thread 3] INFO - rains.ide.BuiltInServerManager - built-in server started, port 63342
2019-01-05 16:34:09,456 [e-1136-b06] INFO - gs.impl.UpdateCheckerComponent - channel: release
2019-01-05 16:34:12,421 [e-1136-b06] INFO - il.indexing.FileBasedIndexImpl - Index exts enumerated:2418, number of extensions:36
2019-01-05 16:34:12,466 [e-1136-b06] INFO - il.indexing.FileBasedIndexImpl - Index scheduled:41
2019-01-05 16:34:12,648 [e-1136-b06] INFO - tellij.psi.stubs.StubIndexImpl - All stub exts enumerated:154, number of extensions:50
2019-01-05 16:34:12,663 [e-1136-b06] INFO - tellij.psi.stubs.StubIndexImpl - stub exts update scheduled:0
2019-01-05 16:34:12,895 [d thread 3] INFO - il.indexing.FileBasedIndexImpl - Version has changed for index filetypes. The index will be rebuilt.
2019-01-05 16:34:22,905 [e-1136-b06] INFO - ellij.project.impl.ProjectImpl - 21 project components initialized in 6496 ms
2019-01-05 16:34:25,678 [e-1136-b06] INFO - com.intellij.ide.ui.UISettings - Loaded: fontSize=12, fontScale=1.0; restored: fontSize=12, fontScale=1.0
2019-01-05 16:34:29,058 [d thread 3] INFO - ij.psi.stubs.StubUpdatingIndex - requesting complete stub index rebuild due to changes: added file types:KNM;
2019-01-05 16:34:29,058 [d thread 3] INFO - il.indexing.FileBasedIndexImpl -
java.io.IOException
at com.intellij.psi.stubs.StubVersionMap.updateState(StubVersionMap.java:127)
at com.intellij.psi.stubs.StubVersionMap.<init>(StubVersionMap.java:69)
at com.intellij.psi.stubs.StubUpdatingIndex$MyIndex.<init>(StubUpdatingIndex.java:427)
at com.intellij.psi.stubs.StubUpdatingIndex.createIndexImplementation(StubUpdatingIndex.java:367)
at com.intellij.util.indexing.FileBasedIndexImpl.createIndex(FileBasedIndexImpl.java:480)
at com.intellij.util.indexing.FileBasedIndexImpl.initIndexStorage(FileBasedIndexImpl.java:412)
at com.intellij.util.indexing.FileBasedIndexImpl.registerIndexer(FileBasedIndexImpl.java:373)
at com.intellij.util.indexing.FileBasedIndexImpl.access$5400(FileBasedIndexImpl.java:117)
at com.intellij.util.indexing.FileBasedIndexImpl$FileIndexDataInitialization.lambda$new$1(FileBasedIndexImpl.java:2399)
at com.intellij.util.indexing.IndexInfrastructure$DataInitialization.executeNestedInitializationTask(IndexInfrastructure.java:214)
at com.intellij.util.indexing.IndexInfrastructure$DataInitialization.runParallelNestedInitializationTasks(IndexInfrastructure.java:202)
at com.intellij.util.indexing.IndexInfrastructure$DataInitialization.call(IndexInfrastructure.java:165)
at com.intellij.util.concurrency.BoundedTaskExecutor$2.run(BoundedTaskExecutor.java:212)
2019-01-05 16:34:29,471 [d thread 3] INFO - ij.psi.stubs.StubUpdatingIndex - Following new file types will be indexed:JAVA,KJSM,XML,LLDBCommands,HTML,Properties,GDBCommands,kotlin_builtins,CLASS,Groovy,KNM,Kotlin
2019-01-05 16:34:30,761 [d thread 3] INFO - il.indexing.FileBasedIndexImpl - Version has changed for index org.jetbrains.kotlin.idea.versions.KotlinJvmMetadataVersionIndex. The index will be rebuilt.
2019-01-05 16:34:31,642 [d thread 3] INFO - pl$FileIndexDataInitialization - Initialization done:19191
2019-01-05 16:34:32,054 [d thread 3] INFO - exImpl$StubIndexInitialization - Initialization done:412
2019-01-05 16:34:32,668 [e-1136-b06] INFO - plication.impl.ApplicationImpl - 90 application components initialized in 44403ms
2019-01-05 16:34:32,708 [e-1136-b06] INFO - .intellij.idea.IdeaApplication - App initialization took 61147 ms
2019-01-05 16:34:34,049 [d thread 3] INFO - ateSettings.impl.UpdateChecker - dl.google.com
at sun.net.
at sun.net.
at sun.net.
at sun.net.
at sun.net.
at sun.net.
at sun.net.
at sun.net.
at sun.net.
at sun.net.
at sun.net.
2019-01-05 16:34:34,065 [d thread 3] INFO - ateSettings.impl.UpdateChecker - Connection failed (dl.google.com). Please check network connection and try again.
2019-01-05 16:34:37,815 [d thread 1] INFO - .openapi.application.Preloader - Finished preloading com.intellij.openapi.actionSystem.impl.ActionPreloader@7c590e51
2019-01-05 16:34:40,940 [d thread 1] INFO - .openapi.application.Preloader - Finished preloading com.intellij.ide.ui.search.SearchableOptionPreloader@6c1fed3a
2019-01-05 16:34:42,503 [d thread 1] INFO - .openapi.application.Preloader - Finished preloading com.intellij.codeInsight.completion.CompletionPreloader@5db00f55
2019-01-05 16:34:42,565 [d thread 1] INFO - .openapi.application.Preloader - Finished preloading com.intellij.ide.actions.GotoClassPresentationUpdater@51f269c3
2019-01-05 16:34:47,441 [d thread 1] WARN - ess.util.ProgressIndicatorBase - This progress indicator is indeterminate, this may lead to visual inconsistency. Please call setIndeterminate(false) before you start progress.
2019-01-05 16:34:47,456 [d thread 1] INFO - s.RepoProgressIndicatorAdapter - Downloading file:/C:/Program%20Files/Android/Android%20Studio/plugins/sdk-updates/offline-repo/offline-repo.xml
2019-01-05 16:34:47,706 [d thread 1] INFO - s.RepoProgressIndicatorAdapter - Downloading
2019-01-05 16:34:47,706 [d thread 1] INFO - s.RepoProgressIndicatorAdapter - IOException:
2019-01-05 16:34:47,706 [d thread 1] INFO - s.RepoProgressIndicatorAdapter - java.io.IOException: Cannot download '
2019-01-05 16:34:47,706 [d thread 1] WARN - s.RepoProgressIndicatorAdapter - Failed to download any source lists!
2019-01-05 16:34:47,706 [d thread 1] INFO - s.RepoProgressIndicatorAdapter - File C:\Users\Gragon IV\.android\repositories.cfg could not be loaded.
2019-01-05 16:34:47,706 [d thread 1] WARN - s.RepoProgressIndicatorAdapter - java.io.IOException: Cannot download '
2019-01-05 16:34:47,769 [e-1136-b06] WARN - vdmanager.AvdManagerConnection - No Android SDK Found
2019-01-05 16:34:49,222 [e-1136-b06] INFO - j.ide.ui.OptionsTopHitProvider - 907 ms spent to cache options in application
2019-01-05 16:34:49,222 [e-1136-b06] INFO - rtup.GradleSpecificInitializer - Found Studio home directory at: 'C:\Program Files\Android\Android Studio'
2019-01-05 16:34:49,222 [e-1136-b06] INFO - rtup.GradleSpecificInitializer - Looking for Android SDK at 'C:/Program Files/Android/Android Studio/sdk'
2019-01-05 16:34:49,222 [e-1136-b06] INFO - rtup.GradleSpecificInitializer - Looking for Android SDK at 'C:/Program Files/Android/sdk'
2019-01-05 16:34:49,222 [e-1136-b06] INFO - rtup.GradleSpecificInitializer - Unable to locate SDK within the Android studio installation.
2019-01-05 16:34:49,222 [e-1136-b06] INFO - rtup.GradleSpecificInitializer - Checking if ANDROID_HOME is set: 'ANDROID_HOME' is 'null'
2019-01-05 16:34:49,222 [e-1136-b06] INFO - rtup.GradleSpecificInitializer - Unable to locate last SDK used by Android tools
2019-01-05 16:34:49,222 [e-1136-b06] INFO - .startup.AndroidSdkInitializer - Found Studio home directory at: 'C:\Program Files\Android\Android Studio'
2019-01-05 16:34:49,222 [e-1136-b06] INFO - .startup.AndroidSdkInitializer - Looking for Android SDK at 'C:/Program Files/Android/Android Studio/sdk'
2019-01-05 16:34:49,222 [e-1136-b06] INFO - .startup.AndroidSdkInitializer - Looking for Android SDK at 'C:/Program Files/Android/sdk'
2019-01-05 16:34:49,222 [e-1136-b06] INFO - .startup.AndroidSdkInitializer - Unable to locate SDK within the Android studio installation.
2019-01-05 16:34:49,222 [e-1136-b06] INFO - .startup.AndroidSdkInitializer - Checking if ANDROID_HOME is set: 'ANDROID_HOME' is 'null'
2019-01-05 16:34:49,222 [e-1136-b06] INFO - .startup.AndroidSdkInitializer - Unable to locate last SDK used by Android tools
2019-01-05 16:34:55,207 [e-1136-b06] WARN - til.ui.update.LazyUiDisposable - use application as a parent disposable
2019-01-05 16:35:19,177 [e-1136-b06] INFO - rd.FirstRunWizardFrameProvider - Overriding welcome frame to be resizable
2019-01-05 16:35:49,100 [e-1136-b06] INFO - ellij.project.impl.ProjectImpl - 157 project components initialized in 2719 ms
2019-01-05 16:35:49,100 [e-1136-b06] INFO - le.impl.ModuleManagerComponent - 0 module(s) loaded in 0 ms
2019-01-05 16:35:49,303 [e-1136-b06] INFO - idea.project.IndexingSuspender - Subscribing project 'Project 'C:\Users\Gragon IV\AndroidStudioProjects\MyApplication' My Application' to indexing suspender events (com.android.tools.idea.project.IndexingSuspender@53b9a29b)
2019-01-05 16:35:49,303 [e-1136-b06] INFO - idea.project.IndexingSuspender - Consuming IndexingSuspender activation event: TEMPLATE_RENDERING_STARTED
2019-01-05 16:35:49,303 [e-1136-b06] INFO - idea.project.IndexingSuspender - Starting batch update for project: Project 'C:\Users\Gragon IV\AndroidStudioProjects\MyApplication' My Application
2019-01-05 16:35:50,788 [e-1136-b06] INFO - rojectCodeStyleSettingsManager - Initialized from default code style settings.
2019-01-05 16:35:50,850 [cessToken]] WARN - BasedStripTrailingSpacesFilter - No current project is given, trailing spaces will be stripped later (postponed). File: C:/Users/Gragon IV/AndroidStudioProjects/MyApplication/build.gradle
2019-01-05 16:35:51,100 [cessToken]] WARN - BasedStripTrailingSpacesFilter - No current project is given, trailing spaces will be stripped later (postponed). File: C:/Users/Gragon IV/AndroidStudioProjects/MyApplication/gradle.properties
2019-01-05 16:35:51,209 [cessToken]] WARN - BasedStripTrailingSpacesFilter - No current project is given, trailing spaces will be stripped later (postponed). File: C:/Users/Gragon IV/AndroidStudioProjects/MyApplication/local.properties
2019-01-05 16:35:51,319 [cessToken]] WARN - BasedStripTrailingSpacesFilter - No current project is given, trailing spaces will be stripped later (postponed). File: C:/Users/Gragon IV/AndroidStudioProjects/MyApplication/settings.gradle
2019-01-05 16:35:51,366 [cessToken]] WARN - BasedStripTrailingSpacesFilter - No current project is given, trailing spaces will be stripped later (postponed). File: C:/Users/Gragon IV/AndroidStudioProjects/MyApplication/app/build.gradle
2019-01-05 16:35:52,381 [cessToken]] WARN - BasedStripTrailingSpacesFilter - No current project is given, trailing spaces will be stripped later (postponed). File: C:/Users/Gragon IV/AndroidStudioProjects/MyApplication/app/build.gradle
2019-01-05 16:35:52,428 [e-1136-b06] WARN - com.intellij.lexer.FlexAdapter - org.jetbrains.plugins.groovy.lang.lexer._GroovyLexer
java.lang.RuntimeException: States does not match: previous=0, expected=4
at org.jetbrains.plugins.groovy.lang.lexer.GroovyLexerBase.yyendstate(GroovyLexerBase.java:54)
at org.jetbrains.plugins.groovy.lang.lexer._GroovyLexer.advance(_GroovyLexer.java:1513)
at com.intellij.lexer.FlexAdapter.locateToken(FlexAdapter.java:110)
at com.intellij.lexer.FlexAdapter.getTokenType(FlexAdapter.java:69)
at com.intellij.lexer.MergingLexerAdapterBase.locateToken(MergingLexerAdapterBase.java:75)
at com.intellij.lexer.MergingLexerAdapterBase.getState(MergingLexerAdapterBase.java:42)
at com.intellij.lexer.LookAheadLexer.doLookAhead(LookAheadLexer.java:71)
at com.intellij.lexer.LookAheadLexer.start(LookAheadLexer.java:148)
at com.intellij.lexer.LookAheadLexer.restore(LookAheadLexer.java:132)
at com.intellij.lexer.LookAheadLexer.restore(LookAheadLexer.java:128)
at com.android.tools.idea.templates.GradleFileSimpleMerger$SimpleGradleBuildFileParser.restoreAndParseUnknown(GradleFileSimpleMerger.java:233)
at com.android.tools.idea.templates.GradleFileSimpleMerger$SimpleGradleBuildFileParser.parseValueList(GradleFileSimpleMerger.java:202)
at com.android.tools.idea.templates.GradleFileSimpleMerger$SimpleGradleBuildFileParser.parseValue(GradleFileSimpleMerger.java:178)
at com.android.tools.idea.templates.GradleFileSimpleMerger$SimpleGradleBuildFileParser.parseBlockOrAssignment(GradleFileSimpleMerger.java:155)
at com.android.tools.idea.templates.GradleFileSimpleMerger$SimpleGradleBuildFileParser.parse(GradleFileSimpleMerger.java:124)
at com.android.tools.idea.templates.GradleFileSimpleMerger$SimpleGradleBuildFileParser.parseBlockOrAssignment(GradleFileSimpleMerger.java:146)
at com.android.tools.idea.templates.GradleFileSimpleMerger.mergeGradleFiles(GradleFileSimpleMerger.java:58)
at com.android.tools.idea.projectsystem.gradle.GradleProjectSystem.mergeBuildFiles(GradleProjectSystem.kt:88)
at com.android.tools.idea.templates.recipe.DefaultRecipeExecutor$RecipeIO.mergeBuildFiles(DefaultRecipeExecutor.java:742)
at com.android.tools.idea.templates.recipe.DefaultRecipeExecutor.merge(DefaultRecipeExecutor.java:356)
at com.android.tools.idea.templates.recipe.Recipe$MergeInstruction.execute(Recipe.java:215)
at com.android.tools.idea.templates.recipe.Recipe.executeInstructions(Recipe.java:120)
at com.android.tools.idea.templates.recipe.Recipe.execute(Recipe.java:105)
at com.android.tools.idea.templates.Template$4.process(Template.java:579)
at com.android.tools.idea.templates.FreemarkerUtils.processFreemarkerTemplate(FreemarkerUtils.java:104)
at com.android.tools.idea.templates.Template.executeRecipeFile(Template.java:568)
at com.android.tools.idea.templates.Template.access$200(Template.java:73)
at com.android.tools.idea.templates.Template$3.startElement(Template.java:530)
at org.apache.xerces.parsers.AbstractSAXParser.startElement(Unknown Source)
at org.apache.xerces.parsers.AbstractXMLDocumentParser.emptyElement(Unknown Source)
at org.apache.xerces.impl.XMLDocumentFragmentScannerImpl.scanStartElement(Unknown Source)
at org.apache.xerces.impl.XMLDocumentFragmentScannerImpl$FragmentContentDispatcher.dispatch(Unknown Source)
at org.apache.xerces.impl.XMLDocumentFragmentScannerImpl.scanDocument(Unknown Source)
at org.apache.xerces.parsers.XML11Configuration.parse(Unknown Source)
at org.apache.xerces.parsers.XMLParser.parse(Unknown Source)
at org.apache.xerces.parsers.AbstractSAXParser.parse(Unknown Source)
at org.apache.xerces.jaxp.SAXParserImpl$JAXPSAXParser.parse(Unknown Source)
at org.apache.xerces.jaxp.SAXParserImpl.parse(Unknown Source)
at com.android.tools.idea.templates.Template.processXml(Template.java:495)
at com.android.tools.idea.templates.Template.processFile(Template.java:479)
at com.android.tools.idea.templates.Template.lambda$doRender$2(Template.java:379)
at com.android.tools.idea.templates.Template$1.run(Template.java:358)
at com.intellij.openapi.application.RunResult.run(RunResult.java:35)
at com.intellij.openapi.command.WriteCommandAction.lambda$null$1(WriteCommandAction.java:175)
at com.intellij.openapi.application.impl.ApplicationImpl.runWriteAction(ApplicationImpl.java:1010)
at com.intellij.openapi.command.WriteCommandAction.lambda$performWriteCommandAction$2(WriteCommandAction.java:174)
at com.intellij.openapi.command.WriteCommandAction.lambda$doExecuteCommand$4(WriteCommandAction.java:214)
at com.intellij.openapi.command.impl.CoreCommandProcessor.executeCommand(CoreCommandProcessor.java:129)
at com.intellij.openapi.command.impl.CoreCommandProcessor.executeCommand(CoreCommandProcessor.java:105)
at com.intellij.openapi.command.WriteCommandAction.doExecuteCommand(WriteCommandAction.java:216)
at com.intellij.openapi.command.WriteCommandAction.performWriteCommandAction(WriteCommandAction.java:172)
at com.intellij.openapi.command.WriteCommandAction.execute(WriteCommandAction.java:155)
at com.android.tools.idea.templates.Template.runWriteCommandAction(Template.java:360)
at com.android.tools.idea.templates.Template.doRender(Template.java:378)
at com.android.tools.idea.templates.Template.lambda$render$0(Template.java:234)
at com.intellij.psi.impl.source.PostprocessReformattingAspect.disablePostprocessFormattingInside(PostprocessReformattingAspect.java:118)
at com.android.tools.idea.templates.Template.render(Template.java:234)
at com.android.tools.idea.npw.model.RenderTemplateModel$FreeMarkerTemplateRenderer.renderTemplate(RenderTemplateModel.java:337)
at com.android.tools.idea.npw.model.RenderTemplateModel$FreeMarkerTemplateRenderer.access$900(RenderTemplateModel.java:213)
at com.android.tools.idea.npw.model.RenderTemplateModel$FreeMarkerTemplateRenderer$1.run(RenderTemplateModel.java:269)
at com.intellij.openapi.command.impl.CoreCommandProcessor.executeCommand(CoreCommandProcessor.java:137)
at com.android.tools.idea.npw.model.RenderTemplateModel$FreeMarkerTemplateRenderer.render(RenderTemplateModel.java:276)
at com.android.tools.idea.npw.model.MultiTemplateRenderer.countDown(MultiTemplateRenderer.java:163)
at com.android.tools.idea.npw.model.MultiTemplateRenderer.skipRender(MultiTemplateRenderer.java:131)
at com.android.tools.idea.npw.model.RenderTemplateModel.handleSkipped(RenderTemplateModel.java:210)
at com.android.tools.idea.wizard.model.ModelWizard.handleFinished(ModelWizard.java:409)
at com.android.tools.idea.wizard.model.ModelWizard.goForward(ModelWizard.java:331)
at com.android.tools.idea.wizard.model.ModelWizardDialog$FinishAction.doAction(ModelWizardDialog.java:307)
at com.intellij.openapi.ui.DialogWrapper$DialogWrapperAction.actionPerformed(DialogWrapper.java:1828)
at javax.swing.AbstractButton.fireActionPerformed(AbstractButton.java:2022)
at javax.swing.AbstractButton$Handler.actionPerformed(AbstractButton.java:2348)
at javax.swing.DefaultButtonModel.fireActionPerformed(DefaultButtonModel.java:402)
at javax.swing.DefaultButtonModel.setPressed(DefaultButtonModel.java:259)
at javax.swing.plaf.basic.BasicButtonListener.mouseReleased(BasicButtonListener.java:252)
at java.awt.Component.processMouseEvent(Component.java:6548)
at javax.swing.JComponent.processMouseEvent(JComponent.java:3325)
at java.awt.Component.processEvent(Component.java:6313)
at java.awt.Container.processEvent(Container.java:2237)
at java.awt.Component.dispatchEventImpl(Component.java:4903)
at java.awt.Container.dispatchEventImpl(Container.java:2295)
at java.awt.Component.dispatchEvent(Component.java:4725)
at java.awt.LightweightDispatcher.retargetMouseEvent(Container.java:4889)
at java.awt.LightweightDispatcher.processMouseEvent(Container.java:4526)
at java.awt.LightweightDispatcher.dispatchEvent(Container.java:4467)
at java.awt.Container.dispatchEventImpl(Container.java:2281)
at java.awt.Window.dispatchEventImpl(Window.java:2746)
at java.awt.EventQueue.dispatchEventImpl(EventQueue.java:764)
at java.awt.EventQueue.access$500(EventQueue.java:98)
at java.awt.EventQueue$3.run(EventQueue.java:715)
at java.awt.EventQueue$3.run(EventQueue.java:709)
at java.security.AccessController.doPrivileged(Native Method)
at java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(ProtectionDomain.java:80)
at java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(ProtectionDomain.java:90)
at java.awt.EventQueue$4.run(EventQueue.java:737)
at java.awt.EventQueue$4.run(EventQueue.java:735)
at java.awt.EventQueue.dispatchEvent(EventQueue.java:734)
at com.intellij.ide.IdeEventQueue.defaultDispatchEvent(IdeEventQueue.java:822)
at com.intellij.ide.IdeEventQueue._dispatchEvent(IdeEventQueue.java:759)
at com.intellij.ide.IdeEventQueue.dispatchEvent(IdeEventQueue.java:423)
at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:201)
at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:116)
at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:109)
at java.awt.WaitDispatchSupport$2.run(WaitDispatchSupport.java:190)
at java.awt.WaitDispatchSupport$4.run(WaitDispatchSupport.java:235)
at java.awt.WaitDispatchSupport$4.run(WaitDispatchSupport.java:233)
at java.awt.WaitDispatchSupport.enter(WaitDispatchSupport.java:233)
at java.awt.Dialog.show(Dialog.java:1077)
at com.intellij.openapi.ui.impl.DialogWrapperPeerImpl$MyDialog.show(DialogWrapperPeerImpl.java:694)
at com.intellij.openapi.ui.impl.DialogWrapperPeerImpl.show(DialogWrapperPeerImpl.java:426)
at com.intellij.openapi.ui.DialogWrapper.invokeShow(DialogWrapper.java:1688)
at com.intellij.openapi.ui.DialogWrapper.show(DialogWrapper.java:1637)
at com.android.tools.idea.actions.AndroidNewProjectAction.actionPerformed(AndroidNewProjectAction.java:84)
at com.intellij.openapi.actionSystem.ex.ActionUtil.invokeAction(ActionUtil.java:337)
at com.intellij.openapi.actionSystem.ex.ActionUtil.invokeAction(ActionUtil.java:324)
at com.intellij.ui.components.labels.ActionLink$1.linkSelected(ActionLink.java:59)
at com.intellij.ui.components.labels.LinkLabel.doClick(LinkLabel.java:142)
at com.intellij.ui.components.labels.ActionLink.doClick(ActionLink.java:68)
at com.intellij.ui.components.labels.LinkLabel$MyMouseHandler.mouseReleased(LinkLabel.java:319)
at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:105)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:101)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:93)
at java.awt.EventDispatchThread.run(EventDispatchThread.java:82)
2019-01-05 16:35:52,444 [cessToken]] WARN - BasedStripTrailingSpacesFilter - No current project is given, trailing spaces will be stripped later (postponed). File: C:/Users/Gragon IV/AndroidStudioProjects/MyApplication/app/build.gradle
2019-01-05 16:35:53,772 [cessToken]] WARN - BasedStripTrailingSpacesFilter - No current project is given, trailing spaces will be stripped later (postponed). File: C:/Users/Gragon IV/AndroidStudioProjects/MyApplication/app/build.gradle
2019-01-05 16:35:53,819 [e-1136-b06] INFO - idea.project.IndexingSuspender - Consuming IndexingSuspender deactivation event: TEMPLATE_RENDERING_FINISHED
2019-01-05 16:35:53,819 [e-1136-b06] INFO - idea.project.IndexingSuspender - Finishing batch update for project: Project 'C:\Users\Gragon IV\AndroidStudioProjects\MyApplication' My Application
2019-01-05 16:35:53,850 [e-1136-b06] INFO - util.EmbeddedDistributionPaths - Looking for embedded Gradle distribution at 'C:\Program Files\Android\Android Studio\gradle\gradle-4.6'
2019-01-05 16:35:53,850 [e-1136-b06] INFO - util.EmbeddedDistributionPaths - Found embedded Gradle 4.6
2019-01-05 16:35:54,272 [d thread 1] INFO - j.ide.script.IdeStartupScripts - 0 startup script(s) found
2019-01-05 16:35:56,507 [d thread 9] INFO - .diagnostic.PerformanceWatcher - Pushing properties took 32ms; general responsiveness: ok; EDT responsiveness: ok
2019-01-05 16:35:56,553 [d thread 4] INFO - ge.ExternalProjectsDataStorage - Loaded external projects data in 31 millis
2019-01-05 16:35:56,850 [d thread 4] INFO - tartup.impl.StartupManagerImpl - WhatsNewStartupActivity run in 172ms under project opening modal progress
2019-01-05 16:35:56,944 [d thread 4] INFO - .diagnostic.PerformanceWatcher - Post-startup activities under progress took 703ms; general responsiveness: ok; EDT responsiveness: ok
2019-01-05 16:35:57,475 [e-1136-b06] INFO - tartup.impl.StartupManagerImpl - C:/Users/Gragon IV/AndroidStudioProjects/MyApplication/.idea case-sensitivity: expected=false actual=false
2019-01-05 16:35:57,538 [d thread 4] INFO - pl.projectlevelman.NewMappings - VCS Root: [] - [<Project>]
2019-01-05 16:35:58,241 [e-1136-b06] INFO - idea.project.IndexingSuspender - Consuming IndexingSuspender activation event: SYNC_TASK_CREATED
2019-01-05 16:35:58,491 [e-1136-b06] INFO - e.project.sync.GradleSyncState - Started sync with Gradle for project 'My Application'.
2019-01-05 16:35:58,507 [e-1136-b06] INFO - idea.project.IndexingSuspender - Consuming IndexingSuspender activation event: SYNC_STARTED
2019-01-05 16:35:58,507 [e-1136-b06] INFO - idea.project.IndexingSuspender - Starting batch update for project: Project 'C:\Users\Gragon IV\AndroidStudioProjects\MyApplication' My Application
2019-01-05 16:35:58,647 [e-1136-b06] INFO - tor.impl.FileEditorManagerImpl - Project opening took 15414 ms
2019-01-05 16:35:59,835 [ thread 11] INFO - s.plugins.gradle.GradleManager - Instructing gradle to use java from C:/Program Files/Android/Android Studio/jre
2019-01-05 16:36:09,960 [ thread 11] INFO - xecution.GradleExecutionHelper - Passing command-line args to Gradle Tooling API: -Didea.version=3.2 -Djava.awt.headless=true -Pandroid.injected.build.model.only=true -Pandroid.injected.build.model.only.advanced=true -Pandroid.injected.invoked.from.ide=true -Pandroid.injected.build.model.only.versioned=3 -Pandroid.injected.studio.version=3.2.1.0 -Pandroid.builder.sdkDownload=false --init-script C:\Users\GRAGON~1\AppData\Local\Temp\ijinit.gradle
2019-01-05 16:36:20,883 [cessToken]] INFO - pl.ProjectRootManagerComponent - project roots have changed
2019-01-05 16:36:25,774 [ thread 11] INFO - .project.GradleProjectResolver - Gradle project resolve error
org.gradle.tooling.BuildException: Could not run build action using Gradle distribution '
https://services.gradle.org/distributions/gradle-4.6-all.zip'.
at org.gradle.tooling.internal.consumer.ExceptionTransformer.transform(ExceptionTransformer.java:51)
at org.gradle.tooling.internal.consumer.ExceptionTransformer.transform(ExceptionTransformer.java:29)
at org.gradle.tooling.internal.consumer.ResultHandlerAdapter.onFailure(ResultHandlerAdapter.java:41)
at org.gradle.tooling.internal.consumer.async.DefaultAsyncConsumerActionExecutor$1$1.run(DefaultAsyncConsumerActionExecutor.java:57)
at org.gradle.internal.concurrent.ExecutorPolicy$CatchAndRecordFailures.onExecute(ExecutorPolicy.java:63)
at org.gradle.internal.concurrent.ManagedExecutorImpl$1.run(ManagedExecutorImpl.java:46)
at org.gradle.internal.concurrent.ThreadFactoryImpl$ManagedThreadRunnable.run(ThreadFactoryImpl.java:55)
at org.gradle.tooling.internal.consumer.BlockingResultHandler.getResult(BlockingResultHandler.java:46)
at org.gradle.tooling.internal.consumer.DefaultBuildActionExecuter.run(DefaultBuildActionExecuter.java:60)
at org.jetbrains.plugins.gradle.service.project.GradleProjectResolver.doResolveProjectInfo(GradleProjectResolver.java:283)
at org.jetbrains.plugins.gradle.service.project.GradleProjectResolver.access$200(GradleProjectResolver.java:79)
at org.jetbrains.plugins.gradle.service.project.GradleProjectResolver$ProjectConnectionDataNodeFunction.fun(GradleProjectResolver.java:939)
at org.jetbrains.plugins.gradle.service.project.GradleProjectResolver$ProjectConnectionDataNodeFunction.fun(GradleProjectResolver.java:923)
at org.jetbrains.plugins.gradle.service.execution.GradleExecutionHelper.execute(GradleExecutionHelper.java:209)
at org.jetbrains.plugins.gradle.service.project.GradleProjectResolver.resolveProjectInfo(GradleProjectResolver.java:140)
at org.jetbrains.plugins.gradle.service.project.GradleProjectResolver.resolveProjectInfo(GradleProjectResolver.java:79)
at com.intellij.openapi.externalSystem.service.remote.RemoteExternalSystemProjectResolverImpl.lambda$resolveProjectInfo$0(RemoteExternalSystemProjectResolverImpl.java:37)
at com.intellij.openapi.externalSystem.service.remote.AbstractRemoteExternalSystemService.execute(AbstractRemoteExternalSystemService.java:58)
at com.intellij.openapi.externalSystem.service.remote.RemoteExternalSystemProjectResolverImpl.resolveProjectInfo(RemoteExternalSystemProjectResolverImpl.java:37)
at com.intellij.openapi.externalSystem.service.remote.wrapper.ExternalSystemProjectResolverWrapper.resolveProjectInfo(ExternalSystemProjectResolverWrapper.java:45)
at com.intellij.openapi.externalSystem.service.internal.ExternalSystemResolveProjectTask.doExecute(ExternalSystemResolveProjectTask.java:100)
at com.intellij.openapi.externalSystem.service.internal.AbstractExternalSystemTask.execute(AbstractExternalSystemTask.java:163)
at com.intellij.openapi.externalSystem.service.internal.AbstractExternalSystemTask.execute(AbstractExternalSystemTask.java:149)
at com.intellij.openapi.externalSystem.util.ExternalSystemUtil$3.execute(ExternalSystemUtil.java:550)
at com.intellij.openapi.externalSystem.util.ExternalSystemUtil$5.run(ExternalSystemUtil.java:647)
Caused by: org.gradle.internal.exceptions.LocationAwareException: A problem occurred configuring root project 'MyApplication'.
at org.gradle.initialization.DefaultExceptionAnalyser.transform(DefaultExceptionAnalyser.java:74)
at org.gradle.initialization.MultipleBuildFailuresExceptionAnalyser.transform(MultipleBuildFailuresExceptionAnalyser.java:47)
at org.gradle.initialization.StackTraceSanitizingExceptionAnalyser.transform(StackTraceSanitizingExceptionAnalyser.java:30)
at org.gradle.initialization.DefaultGradleLauncher.doBuildStages(DefaultGradleLauncher.java:143)
at org.gradle.initialization.DefaultGradleLauncher.getConfiguredBuild(DefaultGradleLauncher.java:110)
at org.gradle.internal.invocation.GradleBuildController$2.call(GradleBuildController.java:87)
at org.gradle.internal.invocation.GradleBuildController$2.call(GradleBuildController.java:84)
at org.gradle.internal.work.DefaultWorkerLeaseService.withLocks(DefaultWorkerLeaseService.java:152)
at org.gradle.internal.invocation.GradleBuildController.doBuild(GradleBuildController.java:100)
at org.gradle.internal.invocation.GradleBuildController.configure(GradleBuildController.java:84)
at org.gradle.tooling.internal.provider.runner.ClientProvidedBuildActionRunner.run(ClientProvidedBuildActionRunner.java:64)
at org.gradle.launcher.exec.ChainingBuildActionRunner.run(ChainingBuildActionRunner.java:35)
at org.gradle.tooling.internal.provider.ValidatingBuildActionRunner.run(ValidatingBuildActionRunner.java:32)
at org.gradle.launcher.exec.RunAsBuildOperationBuildActionRunner$1.run(RunAsBuildOperationBuildActionRunner.java:43)
at org.gradle.internal.progress.DefaultBuildOperationExecutor$RunnableBuildOperationWorker.execute(DefaultBuildOperationExecutor.java:336)
at org.gradle.internal.progress.DefaultBuildOperationExecutor$RunnableBuildOperationWorker.execute(DefaultBuildOperationExecutor.java:328)
at org.gradle.internal.progress.DefaultBuildOperationExecutor.execute(DefaultBuildOperationExecutor.java:199)
at org.gradle.internal.progress.DefaultBuildOperationExecutor.run(DefaultBuildOperationExecutor.java:110)
at org.gradle.launcher.exec.RunAsBuildOperationBuildActionRunner.run(RunAsBuildOperationBuildActionRunner.java:40)
at org.gradle.tooling.internal.provider.SubscribableBuildActionRunner.run(SubscribableBuildActionRunner.java:51)
at org.gradle.launcher.exec.InProcessBuildActionExecuter.execute(InProcessBuildActionExecuter.java:49)
at org.gradle.launcher.exec.InProcessBuildActionExecuter.execute(InProcessBuildActionExecuter.java:32)
at org.gradle.launcher.exec.BuildTreeScopeBuildActionExecuter.execute(BuildTreeScopeBuildActionExecuter.java:39)
at org.gradle.launcher.exec.BuildTreeScopeBuildActionExecuter.execute(BuildTreeScopeBuildActionExecuter.java:25)
at org.gradle.tooling.internal.provider.ContinuousBuildActionExecuter.execute(ContinuousBuildActionExecuter.java:80)
at org.gradle.tooling.internal.provider.ContinuousBuildActionExecuter.execute(ContinuousBuildActionExecuter.java:53)
at org.gradle.tooling.internal.provider.ServicesSetupBuildActionExecuter.execute(ServicesSetupBuildActionExecuter.java:57)
at org.gradle.tooling.internal.provider.ServicesSetupBuildActionExecuter.execute(ServicesSetupBuildActionExecuter.java:32)
at org.gradle.tooling.internal.provider.GradleThreadBuildActionExecuter.execute(GradleThreadBuildActionExecuter.java:36)
at org.gradle.tooling.internal.provider.GradleThreadBuildActionExecuter.execute(GradleThreadBuildActionExecuter.java:25)
at org.gradle.tooling.internal.provider.ParallelismConfigurationBuildActionExecuter.execute(ParallelismConfigurationBuildActionExecuter.java:43)
at org.gradle.tooling.internal.provider.ParallelismConfigurationBuildActionExecuter.execute(ParallelismConfigurationBuildActionExecuter.java:29)
at org.gradle.tooling.internal.provider.StartParamsValidatingActionExecuter.execute(StartParamsValidatingActionExecuter.java:64)
at org.gradle.tooling.internal.provider.StartParamsValidatingActionExecuter.execute(StartParamsValidatingActionExecuter.java:29)
at org.gradle.tooling.internal.provider.SessionFailureReportingActionExecuter.execute(SessionFailureReportingActionExecuter.java:59)
at org.gradle.tooling.internal.provider.SessionFailureReportingActionExecuter.execute(SessionFailureReportingActionExecuter.java:44)
at org.gradle.tooling.internal.provider.SetupLoggingActionExecuter.execute(SetupLoggingActionExecuter.java:45)
at org.gradle.tooling.internal.provider.SetupLoggingActionExecuter.execute(SetupLoggingActionExecuter.java:30)
at org.gradle.launcher.daemon.server.exec.ExecuteBuild.doBuild(ExecuteBuild.java:67)
at org.gradle.launcher.daemon.server.exec.BuildCommandOnly.execute(BuildCommandOnly.java:36)
at org.gradle.launcher.daemon.server.api.DaemonCommandExecution.proceed(DaemonCommandExecution.java:122)
at org.gradle.launcher.daemon.server.exec.WatchForDisconnection.execute(WatchForDisconnection.java:37)
at org.gradle.launcher.daemon.server.exec.ResetDeprecationLogger.execute(ResetDeprecationLogger.java:26)
at org.gradle.launcher.daemon.server.exec.RequestStopIfSingleUsedDaemon.execute(RequestStopIfSingleUsedDaemon.java:34)
at org.gradle.launcher.daemon.server.exec.ForwardClientInput$2.call(ForwardClientInput.java:74)
at org.gradle.launcher.daemon.server.exec.ForwardClientInput$2.call(ForwardClientInput.java:72)
at org.gradle.util.Swapper.swap(Swapper.java:38)
at org.gradle.launcher.daemon.server.exec.ForwardClientInput.execute(ForwardClientInput.java:72)
at org.gradle.launcher.daemon.server.exec.LogAndCheckHealth.execute(LogAndCheckHealth.java:55)
at org.gradle.launcher.daemon.server.exec.LogToClient.doBuild(LogToClient.java:62)
at org.gradle.launcher.daemon.server.exec.EstablishBuildEnvironment.doBuild(EstablishBuildEnvironment.java:82)
at org.gradle.launcher.daemon.server.exec.StartBuildOrRespondWithBusy$1.run(StartBuildOrRespondWithBusy.java:50)
at org.gradle.launcher.daemon.server.DaemonStateCoordinator$1.run(DaemonStateCoordinator.java:295)
Caused by: org.gradle.api.ProjectConfigurationException: A problem occurred configuring root project 'MyApplication'.
at org.gradle.configuration.project.LifecycleProjectEvaluator.addConfigurationFailure(LifecycleProjectEvaluator.java:94)
at org.gradle.configuration.project.LifecycleProjectEvaluator.doConfigure(LifecycleProjectEvaluator.java:66)
at org.gradle.configuration.project.LifecycleProjectEvaluator.access$100(LifecycleProjectEvaluator.java:34)
at org.gradle.configuration.project.LifecycleProjectEvaluator$ConfigureProject.run(LifecycleProjectEvaluator.java:110)
at org.gradle.configuration.project.LifecycleProjectEvaluator.evaluate(LifecycleProjectEvaluator.java:50)
at org.gradle.api.internal.project.DefaultProject.evaluate(DefaultProject.java:667)
at org.gradle.api.internal.project.DefaultProject.evaluate(DefaultProject.java:136)
at org.gradle.execution.TaskPathProjectEvaluator.configure(TaskPathProjectEvaluator.java:35)
at org.gradle.execution.TaskPathProjectEvaluator.configureHierarchy(TaskPathProjectEvaluator.java:60)
at org.gradle.configuration.DefaultBuildConfigurer.configure(DefaultBuildConfigurer.java:38)
at org.gradle.initialization.DefaultGradleLauncher$ConfigureBuild.run(DefaultGradleLauncher.java:261)
at org.gradle.initialization.DefaultGradleLauncher.configureBuild(DefaultGradleLauncher.java:173)
at org.gradle.initialization.DefaultGradleLauncher.doBuildStages(DefaultGradleLauncher.java:132)
... 62 more
Caused by: org.gradle.api.internal.artifacts.ivyservice.DefaultLenientConfiguration$ArtifactResolveException: Could not resolve all artifacts for configuration ':classpath'.
at org.gradle.api.internal.artifacts.configurations.DefaultConfiguration.rethrowFailure(DefaultConfiguration.java:944)
at org.gradle.api.internal.artifacts.configurations.DefaultConfiguration.access$1600(DefaultConfiguration.java:120)
at org.gradle.api.internal.artifacts.configurations.DefaultConfiguration$ConfigurationArtifactCollection.ensureResolved(DefaultConfiguration.java:1285)
at org.gradle.api.internal.artifacts.configurations.DefaultConfiguration$ConfigurationArtifactCollection.getArtifacts(DefaultConfiguration.java:1257)
at org.gradle.composite.internal.CompositeBuildClassPathInitializer.execute(CompositeBuildClassPathInitializer.java:42)
at org.gradle.composite.internal.CompositeBuildClassPathInitializer.execute(CompositeBuildClassPathInitializer.java:29)
at org.gradle.api.internal.initialization.DefaultScriptClassPathResolver.resolveClassPath(DefaultScriptClassPathResolver.java:37)
at org.gradle.api.internal.initialization.DefaultScriptHandler.getScriptClassPath(DefaultScriptHandler.java:72)
at org.gradle.plugin.use.internal.DefaultPluginRequestApplicator.defineScriptHandlerClassScope(DefaultPluginRequestApplicator.java:204)
at org.gradle.plugin.use.internal.DefaultPluginRequestApplicator.applyPlugins(DefaultPluginRequestApplicator.java:82)
at org.gradle.configuration.DefaultScriptPluginFactory$ScriptPluginImpl.apply(DefaultScriptPluginFactory.java:184)
at org.gradle.configuration.BuildOperationScriptPlugin$1.run(BuildOperationScriptPlugin.java:61)
at org.gradle.configuration.BuildOperationScriptPlugin.apply(BuildOperationScriptPlugin.java:58)
at org.gradle.configuration.project.BuildScriptProcessor.execute(BuildScriptProcessor.java:41)
at org.gradle.configuration.project.BuildScriptProcessor.execute(BuildScriptProcessor.java:26)
at org.gradle.configuration.project.ConfigureActionsProjectEvaluator.evaluate(ConfigureActionsProjectEvaluator.java:34)
at org.gradle.configuration.project.LifecycleProjectEvaluator.doConfigure(LifecycleProjectEvaluator.java:64)
... 81 more
Caused by: org.gradle.internal.resolve.ModuleVersionResolveException: Could not resolve org.jetbrains.kotlin:kotlin-reflect:1.2.0.
Required by:
project : > com.android.tools.build:gradle:3.2.1 > com.android.tools.lint:lint-gradle-api:26.2.1
project : > com.android.tools.build:gradle:3.2.1 > com.android.tools.build:builder:3.2.1 > com.android.tools:sdk-common:26.2.1
at org.gradle.api.internal.artifacts.ivyservice.ivyresolve.RepositoryChainComponentMetaDataResolver.resolveModule(RepositoryChainComponentMetaDataResolver.java:103)
at org.gradle.api.internal.artifacts.ivyservice.ivyresolve.RepositoryChainComponentMetaDataResolver.resolve(RepositoryChainComponentMetaDataResolver.java:63)
at org.gradle.api.internal.artifacts.ivyservice.resolveengine.ComponentResolversChain$ComponentMetaDataResolverChain.resolve(ComponentResolversChain.java:93)
at org.gradle.api.internal.artifacts.ivyservice.clientmodule.ClientModuleResolver.resolve(ClientModuleResolver.java:60)
at org.gradle.api.internal.artifacts.ivyservice.resolveengine.graph.builder.ComponentState.resolve(ComponentState.java:163)
at org.gradle.api.internal.artifacts.ivyservice.resolveengine.graph.builder.ComponentState.getMetaData(ComponentState.java:174)
at org.gradle.api.internal.artifacts.ivyservice.resolveengine.graph.builder.EdgeState.calculateTargetConfigurations(EdgeState.java:137)
at org.gradle.api.internal.artifacts.ivyservice.resolveengine.graph.builder.EdgeState.attachToTargetConfigurations(EdgeState.java:108)
at org.gradle.api.internal.artifacts.ivyservice.resolveengine.graph.builder.DependencyGraphBuilder.attachToTargetRevisionsSerially(DependencyGraphBuilder.java:236)
at org.gradle.api.internal.artifacts.ivyservice.resolveengine.graph.builder.DependencyGraphBuilder.resolveEdges(DependencyGraphBuilder.java:226)
at org.gradle.api.internal.artifacts.ivyservice.resolveengine.graph.builder.DependencyGraphBuilder.traverseGraph(DependencyGraphBuilder.java:140)
at org.gradle.api.internal.artifacts.ivyservice.resolveengine.graph.builder.DependencyGraphBuilder.resolve(DependencyGraphBuilder.java:111)
at org.gradle.api.internal.artifacts.ivyservice.resolveengine.DefaultArtifactDependencyResolver.resolve(DefaultArtifactDependencyResolver.java:92)
at org.gradle.api.internal.artifacts.ivyservice.DefaultConfigurationResolver.resolveGraph(DefaultConfigurationResolver.java:146)
at org.gradle.api.internal.artifacts.ivyservice.ShortCircuitEmptyConfigurationResolver.resolveGraph(ShortCircuitEmptyConfigurationResolver.java:73)
at org.gradle.api.internal.artifacts.ivyservice.ErrorHandlingConfigurationResolver.resolveGraph(ErrorHandlingConfigurationResolver.java:66)
at org.gradle.api.internal.artifacts.configurations.DefaultConfiguration$4.run(DefaultConfiguration.java:494)
at org.gradle.api.internal.artifacts.configurations.DefaultConfiguration.resolveGraphIfRequired(DefaultConfiguration.java:485)
at org.gradle.api.internal.artifacts.configurations.DefaultConfiguration.resolveToStateOrLater(DefaultConfiguration.java:470)
at org.gradle.api.internal.artifacts.configurations.DefaultConfiguration.access$1700(DefaultConfiguration.java:120)
at org.gradle.api.internal.artifacts.configurations.DefaultConfiguration$ConfigurationFileCollection.getSelectedArtifacts(DefaultConfiguration.java:927)
at org.gradle.api.internal.artifacts.configurations.DefaultConfiguration$ConfigurationFileCollection.access$2700(DefaultConfiguration.java:861)
at org.gradle.api.internal.artifacts.configurations.DefaultConfiguration$ConfigurationArtifactCollection.ensureResolved(DefaultConfiguration.java:1279)
... 99 more
at org.gradle.api.internal.artifacts.ivyservice.ivyresolve.ErrorHandlingModuleComponentRepository$ErrorHandlingModuleComponentRepositoryAccess.resolveComponentMetaData(ErrorHandlingModuleComponentRepository.java:139)
at org.gradle.api.internal.artifacts.ivyservice.ivyresolve.ComponentMetaDataResolveState.process(ComponentMetaDataResolveState.java:66)
at org.gradle.api.internal.artifacts.ivyservice.ivyresolve.ComponentMetaDataResolveState.resolve(ComponentMetaDataResolveState.java:58)
at org.gradle.api.internal.artifacts.ivyservice.ivyresolve.RepositoryChainComponentMetaDataResolver.findBestMatch(RepositoryChainComponentMetaDataResolver.java:138)
at org.gradle.api.internal.artifacts.ivyservice.ivyresolve.RepositoryChainComponentMetaDataResolver.findBestMatch(RepositoryChainComponentMetaDataResolver.java:119)
at org.gradle.api.internal.artifacts.ivyservice.ivyresolve.RepositoryChainComponentMetaDataResolver.resolveModule(RepositoryChainComponentMetaDataResolver.java:92)
... 125 more
Caused by: org.gradle.api.resources.ResourceException: Could not get resource '
https://dl.google.com/dl/android/ma...kotlin-reflect/1.2.0/kotlin-reflect-1.2.0.pom'.
at org.gradle.internal.resource.ResourceExceptions.failure(ResourceExceptions.java:74)
at org.gradle.internal.resource.ResourceExceptions.getFailed(ResourceExceptions.java:57)
at org.gradle.api.internal.artifacts.repositories.resolver.DefaultExternalResourceArtifactResolver.downloadByCoords(DefaultExternalResourceArtifactResolver.java:147)
at org.gradle.api.internal.artifacts.repositories.resolver.DefaultExternalResourceArtifactResolver.downloadStaticResource(DefaultExternalResourceArtifactResolver.java:98)
at org.gradle.api.internal.artifacts.repositories.resolver.DefaultExternalResourceArtifactResolver.resolveArtifact(DefaultExternalResourceArtifactResolver.java:65)
at org.gradle.api.internal.artifacts.repositories.metadata.AbstractRepositoryMetadataSource.parseMetaDataFromArtifact(AbstractRepositoryMetadataSource.java:69)
at org.gradle.api.internal.artifacts.repositories.metadata.AbstractRepositoryMetadataSource.create(AbstractRepositoryMetadataSource.java:59)
at org.gradle.api.internal.artifacts.repositories.resolver.ExternalResourceResolver.resolveStaticDependency(ExternalResourceResolver.java:199)
at org.gradle.api.internal.artifacts.repositories.resolver.MavenResolver.doResolveComponentMetaData(MavenResolver.java:117)
at org.gradle.api.internal.artifacts.repositories.resolver.ExternalResourceResolver$RemoteRepositoryAccess.resolveComponentMetaData(ExternalResourceResolver.java:400)
at org.gradle.api.internal.artifacts.ivyservice.ivyresolve.CachingModuleComponentRepository$ResolveAndCacheRepositoryAccess.resolveComponentMetaData(CachingModuleComponentRepository.java:381)
at org.gradle.api.internal.artifacts.ivyservice.ivyresolve.ErrorHandlingModuleComponentRepository$ErrorHandlingModuleComponentRepositoryAccess.resolveComponentMetaData(ErrorHandlingModuleComponentRepository.java:136)
... 130 more
Caused by: org.gradle.internal.resource.transport.http.HttpRequestException: Could not HEAD '
at org.gradle.internal.resource.transport.http.HttpClientHelper.performRequest(HttpClientHelper.java:96)
at org.gradle.internal.resource.transport.http.HttpClientHelper.performRawHead(HttpClientHelper.java:72)
at org.gradle.internal.resource.transport.http.HttpClientHelper.performHead(HttpClientHelper.java:76)
at org.gradle.internal.resource.transport.http.HttpResourceAccessor.getMetaData(HttpResourceAccessor.java:65)
