Since recently switching everything over from my old [primary] laptop to my new [primary] laptop, I've been struggling with Dropbox issues. Its settings are very limited, so there isn't a lot of tweaking I can do via its desktop client or its web site. I'm actually baffled by its 'logic'...such as it is. The main issue is as follows.
Consider this:
1) a directory named /data/media/images
2) a directory named ~/Dropbox
I want the contents of #1 to be backed up online in my Dropbox account.
According to Dropbox, anything I want saved online has to be in my Dropbox directory, which in my case is the default location of #2. BUT, to accomplish that, I either have to MOVE my images directory (which has zillions of subdirectories and bazillions of files in them) from my desired location in /data/media to ~/Dropbox, or I have to copy it there, or, less reliably, I can link it there. NONE of these choices is good for me. The first means changing my directory structure, which is bad because I have extensive scripting referring to various directories. The second means using double the disk space locally, and the latter is not 100% reliable.
But worse than that, what I've found is that if I delete a file or directory locally, it ALSO gets deleted from my online Dropbox account. That CANNOT possibly be the correct behavior, can it?
Say that I copied /data/media/images/beaches to ~/Dropbox/beaches. Its files get uploaded to my Dropbox account. Great! I'm using Dropbox for backup purposes, so the files are there, all's good, right? Wrong! If I now delete ~/Dropbox/beaches, it ALSO is deleted from my online account.
Isn't the whole point that you're supposed to rest assured, knowing that if some catastrophe happens at your end, like disk failure or accidental deletion of files, that you can RETRIEVE those files from your online account? That's how *I* think it's supposed to work...but apparently not. And I'm absolutely baffled by that. If I accidentally...while logged in as root...rm -rf /...
(Note to anyone who doesn't know: DO NOT issue that command while logged in as root! It will yield very, very bad results.)
What am I missing? I must be missing something because Dropbox simply doesn't work the way I think it should.
Consider this:
(Note to anyone who doesn't know: DO NOT issue that command while logged in as root! It will yield very, very bad results.)What am I missing? I must be missing something because Dropbox simply doesn't work the way I think it should.
