Root [solved] GTA: SA stuck on start screen
Incakola
Anyone else had this problem where when you start the game and the loading symbol starts and then the game seems to minimize itself then it pops back up to the start screen with the start and settings buttons there but I can't touch them. I tried reinstalling the game, tried to use app settings in xposed, turning off lux. I'm rooted running Franco with the DU rom.
Since you're rooted (and therefore have way more troubleshooting options), I've moved this to the root forums.
I've got a game that crashes on startup for me as well.
Have you tried different ROMS/kernels? I just wonder if DPI settings or something else is crashing it
Are you restoring from tiBu or reinstalling from market?
I know you said you tried both above, but reinstallation may work on stock
Found out what it was when I noticed that the interface would not accept touch responses. An app was writing over it like lux or any other screen filter app. I tested lux first then went down the list of apps that I know writes over other apps and apparently an xposed app called swipeback was causing the problem all along.
