[SOLVED] how to change language from japanese to english
I changed my Android language from English to Japanese, but now I'm having trouble navigating the settings menus to change it back. Can someone help me drill down into the correct menu?
I don't know what phone or tablet you've got there, and where in the Settings menu it might be. But try looking for something like "言語と入力" which means "Language & input". Depending on the device and its software, it might be in a sub-menu from settings. Also are you sure it's actually Japanese, and not Chinese, or Korean, or something?
You could try Google Translate using the camera on another phone, which might give you some idea of what you're looking at.
It should not be difficult to go back from Japanese to English. You may post a screenshot of each steps, we'll help you manage to point out which menu items you should select then.
Here you go.
