1. Manufacturer - (OnePlus)
2. Model - (7 Pro)
3. Software version - (Android 10)
4. Specifics of the problem
Hi everybody, it seems that no one has had this issue or I lack the Smartphone knowledge to find the specific answer to my problem.
Just around one hour ago I wanted to listen to some music while taking a walk with my dog. I noticed that my phone's batteries died. No biggie, connected it to the Warp charger and walked my dog without music.
Came back, Battery already at 33% turned it on, logged in with my lock screen pin, and nothing besides my 3 Buttons (Home, Back, and Overview), the Wallpaper and the top bar (don't know what its called) are showing.
Apps are running since every time I do a restart, my McAfee Notification pops up. I can swipe down to access system settings, set Fly Mode, etc.
When I lock the screen with the right button and unlock it, sometimes the lock screen appears, sometimes it doesn't. Same with the 3 Buttons, sometimes they appear and sometimes they don't.
Restarted with Safe Mode, cleared System UI Cache still the same issue. I can't swipe to any side besides down.
Up doesn't show all my apps, swiping right won't bring up the page with the calculator, and swiping left won't show the rest of the apps on the home screen.
When I access an app through settings>apps and press the overview button either nothing happens or it goes to the blank home screen with just the wallpaper showing or it bugs out in a weird way and then shows only the wallpaper and nothing else.
The weird thing is, that just the battery died, I haven't used that phone all day long. Only after turning it on while it was charging started all this mess.
Now before I factory reset the phone and lose all my stuff, is this problem known, and is there a fix. I'm at my Wit's end, I know my way around PC's but Smartphones are uncharted lands for me.
Thanks in advance.
2. Model - (7 Pro)
Thanks in advance.
