Griever
Member
I posted this on a post but felt it needed its own thread, you can sticky it if you think it will be more useful
Picked up a tip for other 'wet phone accidents'. Don't use rice AND DON'T PUT YOUR PHONE ON, the best way to sort a wet phone is alcohol gel (the stuff used in hosptial for your hands). 90% alcohol or more (you can buy that at a chemist or supermarket). Get a resealable bag. Put the alcohol gel in the resealable bag, drop your phone in-minus the battery/sim/memory card and shake it around a bit take-make sure the gel gets everywhere. Leave it a few minutes, bring it out and leave it sitting for a bit. And voila
**Yes... I know what your thinking, why wet an already wet phone... Well the alcohol gel evaporates at room temperature, it also more or less eats away the water in the phone.
As another tip for water damage, get some scotch tape and put it over each moisture indicator when you return your phone-remove it. This may or may not work, however I don't recommend anyone try it, its just a point of conversation!!
