some rooted are not opening
kirankvb
hello
i rooted my phone with kingroot. it says that i am fully rooted
but some apps like supersu,tasker,titanium backup,apps2sd are not opening .some apps like titanium backup and apps2sd are opening but they stuck at checking for root permission, even though i granted the root permission but they still act like they need root permission
and some apps like tasker and supersu wont even open , like it force closes whenever i opens
and the boot-loader cant be unlocked for my phone
and i made a video regarding this problem :
Tasker doesn't need root apart from a couple of options, so if that won't even open there's more than just root having failed. Do know how to reflash the stock system on your phone, in case Kingroot has messed it up?
And it sounds like rooting did fail, whatever Kingroot told you. By all means download a root checker app to test, but if no app that requires root will work that's the obvious conclusion.
i flashed over a hundred times but problem didn't fixed
the only rooting script available is only in the kingroot
even though kingoroot did root my mobile ,the superuser app that it came with rooting wont open . same problem appear at that time
and for the root permission i checked over many apps and every app successfully verified that i am having root permission
note: "kingoroot" differes from "kingroot"
There's some interesting comments on rooting this model on XDA's site:
https://forum.xda-developers.com/android/help/lyf-flame-1-custom-recovery-t3453265
(... regarding your screen cap, there's that Lucky Patcher icon. Please stop using that app, denying developers from their ad revenue is not a good practice.)
sorry to say that i don't have any intention to remove the ads,i just want you to know that the "integrate the updates to system" wont work . it just loads for ever
and the post referring in your previous post is mine and i fed up with those worst answers
they just only referring the basic steps an no answer is being perfect
i tried everything and came to he ending as that i have to modify the aboot.img" in order to be bootloader unlock-able
Kingroot , how did you succeed ? when I used it to root my phone last month,after I have finished, I found out that the original data had been erased on my phone ,
what !!!
root doesn't erase your data
but if it happens, that maybe because of some security created by the manufacturers
Yeh, they're different companies in China, but they're both monetized by spam, ads and data mining you.
Good luck!
BTW. I usually don't recommend any "free" Chinese exploit rooting tools.
