Someone PLEASE HELP! Sticky Note AND notepad - WTF?
DCmagic
OK here is what the issue seems to be.
If notepad has it, sticky doesnt, if sticky has it, then notepad doesnt.
This is what im looking for.
I have STICKY NOTE:
cool free app, but you need to go to Home > Widgets > Sticky Note to make a new one. It would be nice if there was an icon on the homescreen to add a new note.
Or better yet, Note pad is awsome for memos, but you need to open it to view.
So the question is....
Is there an app out there, either a sticky, or notepad.
Where there is a WIDGET on the homescreen, almost like a picture frame, but bigger. Where you can SEE YOUR NOTES RIGHT THERE. you dont have to open it up, or do anything, basicly it like takes up one of the 3 homes screens you can have. so flick to the right screen (on G1 phone) and theres all your notes, tap it to add a new one. and thats it, you can see it right there.
Kinda like a notepad list, but you can view it in widget form, on the home screen.
Now something like that would be nice if its not out...
Any suggestions?
Thank you! :)
Color Notes...
You can create notes or check lists.
You can view them by opening the app.
Or you can stick them on your home screen with widgets.
You can also program them to send you reminders on your status bar.
Free, and simple.
