Song as Notification Sound for HTC Evo
  • Start date Start date
A
Android Question
Guest
I have a sound that is saved in my music. I would like to make it my text notification sound. How do I do this. Thank you.
Welcome to the guest forums!
There are actually apps in the Play Store that can help with this. One of my favorites is RingDroid.
https://play.google.com/store/apps/details?id=com.ringdroid
This app allows you to use either the entire song or just one portion for a ringtone, and you can assign it as your default ringtone or for a particular contact.
For an SMS notification ringtone, however, you might have tip use an app like Mp3 ringtone cutter.
https://play.google.com/store/apps/details?id=com.backstone.mp3.cutter
Hope that helps!
