Sound and Automation
lakersfreak
I love my S10+. Only have one issue I can't figure out.
Is there a way to add a sound mode? All there is in the settings is Sound, Vibrate, and Mute. I would like to add a sound mode for the office so I can have all the volumes lowered while at work. The Bixby Routines is cool and I will be able to automate this function, but I need to be able to add a sound mode.
If not possible through the phone, what app do you guys recommend? I am currently using Sound Profile but it does not work well on the S10+ at all.
Yes, download Sound Assistant by Samsung from the Galaxy Store. It has a feature for just this. You can set it to change when you're at home, work or driving.
