Help Sound is very low.
This happened before but i fixed it. Now its happening again and it won't stop. My GS2s volume is all the way up and i Still can't here anything. Like now i tried to listen to music that works on the phone and you can only hear it if you have the speaker directly next to your ear.:mad: Even on games, it can't be heard thanks for reading. Please help if you can.
Been having a similar problem with my Boost GS2, Recently used a different root on it. Has had less bugs with it... Except it wouldn't ring when I get a phone call!! Anyway I checked my "Quicker" App's volume control, it showed everything was good, then I checked out the sound settings and noticed the volume section. all the section were set at zero except the media volume which was set where I had it. Anyway check it out, hopefully thats all it is.
