Sound mode problem
Make sure you have not set custom do not disturb times on your phone....Are there any apps you install that have control over volume/notifications, could it be your case pushing the buttons?
Whoa...Replying to your own comment 4 times isn't going to get you help any quicker...
Did you check the other two things I mentioned first? I know it may be off now, but do you have it on a schedule? - Are you using a case? Apps are the hardest to identify. You can start by booting the phone in safe mode to see if the issue persists. If it does not happen in safe mode, it is likely an app that is causing the problem and you will have to isolate it by uninstalling one app at a time, or uninstalling all the apps and reinstalling them one at a time.
