Help Sound out of sync?
BertEddie
Hi,
Does anyone else have a problem with downloaded video files and the sound being out sync? Tried numerous files and players, but the sound lags the pic enough to be bloody annoying!!
I've tried Mediascape, Act 1 and mVideo, al with same result.
Any suggestions please?
It might be the video you're watching rather than your phone. Also, if you're streaming, it's quite common so try using Wi-Fi instead
-pup-
Thanks for the reply, but I've tried numerous different files. They are downloaded, not streamed.
Can I assume you're not having this issue?
So are you downloading from your pc and transferring to the x10 or are you downloading from x10 browser?
I have not had problems with from pc to x10 so if its from x10 browser then I will give it a test to check.
I'm downloading .mp4 files from the x10 browser. I'll try and download the same file on to my PC and transfer and see if that sorts it.
Thanks for the suggestion.
