spb shell 3D
x10iii
has anyone tried this? looks epic, but its $15! and i have a feeling it mite lag like crazy..
I installed it yesterday on my x10i - it doesn't even start to run, although I have seen claims from other x10i owners that it runs fine on their handset
I installed this today runs perfectly really smoth very nice program but ultimatly you cant customise it much in my opinion its not worth the time i spent 4 hours trying to make it how i want and in the end i gave up and uninstalled it not worth it untill they get a LOT more customisation but thats just my 2 cents
any way if you want to try it for free just download it and put it on using flash tool it will only let you run it once untill the phone is reset but it will give you a feel for it befor you spend al that money
I take no responsability if you download an app that is not safe or what it claims to be!
afker downloading the .apk file place it in to your flash tools folder (flashtools/custom/apps)
then run flash tools use with root access and press the custom button this will install any apps in your custom/apps folder close it down reboot the phone when it starts you will have the option to use spb for home launch it will say you havnt paid and must uninstall igrnor it and you can play with it untill you restart the phone again or press menu button should be more than enough to give you a feel you can try all the features and mess around looks good but not very use full i think
also sorry but i cant advise where to download the app i havnt found a web site that i know is 100% safe so just look around for .apk download web sites good luck
Theres no need to do all tht...its the same as downloading the apk. Normally...u talk a whole load of crapk:L
Ive run it just fine on my phone. It is very cool, but after the first install it wants you to buy it. I like it but not for 15 bucks. Runs smooth on my 2.2-2.3 Roms.
You mean... Panda website? lol
