Speaker Fixer - Clean Dust & Remove Water & Boost
3xcellency
Speaker Fixer app uses sine wave sounds of frequencies to remove water and clean dust from the speaker. Sound waves cause the speaker to vibrate and shake off water stuck inside and dust.
Easy to use.
-Selectable Extra Volume mod for dirty speakers
-Selectable Low/High Frequency
-Choose all speaker
You can choose between cleaning loud speaker or ear speaker
https://play.google.com/store/apps/details?id=com.ozan.speakerfixer
