SPEAKER mode audio fades while in call
JTX
The speakerphone audio on my Pixle 2 while in speaker mode fades after 5-10 seconds.
The audio on a bluetooth connected device does the same thing.
I booted in SAFE MODE and the problem persists less often however still occurs. While in safe mode if I push speaker OFF then ON again, it generally returns to normal speakerphone volume but then will suddenly drop the speakerphone audio if you talk into it.
Any suggestions?
Hmm, I was ready to say that it was a hardware problem with the speaker itself (we've seen a few of those) but it's really odd that the same thing would happen while using a Bluetooth device. Safe Mode should have effectively ruled out the possibility of a third-party app causing problems.
Is this only a problem while on calls or does the media audio (say from a youtube video) also fade out?
Very interesting. Have you tried clearing the cache and/or storage for the Phone app to see if that has any impact?
Yeah It didnt fix it. I even did a factory reset, and same problem popped back up.
Going to call it dead and replace it unfortunately. It's barely been two years........
I do appreciate the reply
