Speaker problem
alengyel
Hi,
I have the following problem. During a call the sounds don't come through the "front" speaker but the loudspeaker on the back. When I trun to the loudspeaker mode during thecall, it works fine. The same speaker works but louder. When turning back to normal mode, the back speaker works on but much more silent. I did factory reset many times, also put on an official firmware then a CM7 nighly ROM. Is it a hw problem? Is there any trick I can do home?
Regards,
alengyel
Hi,
Regards,
alengyel
hello, if it occurs in the stock rom, can be a problem of, unintentionally, during the call you connect your speaker, you must turn on the proximity sensor: System Menu => Call settings => additional settings => Turn on proximity sensor.
Or can be a hadware problem.
However you should be aware that nightly versions are in development, so do have bugs, which can be like that you now describe. Try a stock rom or a rom stable
