Exilereven
Hello, I have been searching all over the net trying to find a way to quickly get repetitive screencaps to pull pixel colors from. this is my tasker task I'm using to get the job done below.
I'm wondering how I can improve performance of the piece as a whole, or at least speed up my screenshots, or figure out why my tasker coding skills may be sub par lol. if anyone has any ideas how to speed this up I would love any advice, please and thank you.
Side note-it needs to stay root for the screencaps, because the app I'm getting them from doesn't like normal ones lol.
Phone: galaxy note 3
Android 5.0 lollipop
This is the get pixel code I'm using, I call this with perform task so b I can get color at pixel.
Pixel Color (6)
A1: Variable Set [ Name:%devicewidth To:1080 Do Maths:Off Append:Off ]
A2: Variable Set [ Name:%par1 To:100 Do Maths:Off Append:Off ] If [ %par1 !Set ]
A3: Variable Set [ Name:%par2 To:100 Do Maths:Off Append:Off ] If [ %par2 !Set ]
A4: Variable Set [ Name:%offset To:%par2 * %devicewidth + %par1 Do Maths:On Append:Off ]
A5: Run Shell [ Command:su -cn u:r:system_app:s0
screencap /sdcard/scr.dump;
let offset=%offset;
stringZ=$(dd if='/sdcard/scr.dump' bs=4 count=1 skip=$offset 2>/sdcard/result.txt| hexdump);
red=$(echo $stringZ | cut -d' ' -f2 | tail -c3);
green=$(echo $stringZ | cut -d' ' -f2 | head -c2);
blue=$(echo $stringZ | cut -d' ' -f3 | tail -c3);
rgb="#$red$green$blue";
echo $rgb; Timeout (Seconds):20 Use Root:On Store Output In:%final Store Errors In: Store Result In: ]
A6: Return [ Value:%final Stop:On ]
This is the code I use in my main script. which I'm trying to get either to run faster, or point me in the right direction lol.
Shell Top Works Perfect (11)
A1: Variable Set [ Name:%attacking To:0 Do Maths:Off Append:Off ]
<beginloop>
A2: Anchor
A3: Perform Task [ Name
ixel Color Priority:%priority + 1 Parameter 1 (%par1):730 Parameter 2 (%par2):907 Return Value Variable:%color Stop:Off ]
A4: If [ %attacking ~ 2 ]
A5: Stop [ With Error:Off Task: ]
A6: Else If [ %attacking ~ 1 ]
A7: Goto [ Type:Action Label Number:1 Label:still attacking top ]
A8: End If
<start attacking top>
A9: If [ %color ~ #19ba4a | %color ~ #e6ff00 | %color ~ #efff00 | %color ~ #21ba4a &+ %attacking ~ 0 ]
A10: Variable Set [ Name:%attacking To:1 Do Maths:Off Append:Off ]
A11: Run Shell [ Command:input tap 960 400 Timeout (Seconds):0 Use Root:On Store Output In: Store Errors In: Store Result In: ]
A12: Goto [ Type:Action Label Number:1 Label:beginloop ]
<still attacking top>
A13: Else If [ %color ~ #19ba4a | %color ~ #e6ff00 | %color ~ #21ba4a | %color ~ #eeff00 &+ %attacking ~ 1 ]
A14: Goto [ Type:Action Label Number:1 Label:beginloop ]
<top is red>
A15: Else If [ %color ~ #ce3531 | %color ~ #ce3131 ]
A16: Run Shell [ Command:input tap 960 400 Timeout (Seconds):0 Use Root:On Store Output In: Store Errors In: Store Result In: ]
A17: Variable Set [ Name:%attacking To:2 Do Maths:Off Append:Off ]
A18: Goto [ Type:Action Label Number:1 Label:beginloop ]
A19: Else
A20: Variable Set [ Name:%attacking To:2 Do Maths:Off Append:Off ]
A21: Goto [ Type:Action Label Number:1 Label:beginloop ]
A22: End If
Pixel Color (6)
let offset=%offset;
<beginloop>
A2: Anchor
A8: End If
<top is red>
A19: Else
A22: End If
