Speed Up Your Smartphone with Memory Booster
  • Thread starter Thread starter Jackdroid
  • Start date Start date
J
Jackdroid
Guest
Memory Booster:Android RAM Optimizer to Speed Up Your Smartphone!
Memory Booster offers a memory optimization app with a bit of graphical flair. The light version allows you to do a quick boost and shows exactly how much memory is being used and freed. The paid version allows you to set a threshold for the program to automatically kill tasks and boost the memory when it hits a certain percentage you decide. Paid version also offers an
I've used it, but can't recommend it (though not for the reason above). Basically, it's a task killer that will run for you in the background. The problem I have with it is that the white list that keeps certain apps from being closed doesn't work as well as it should; I can't tell you how many times Weather Bug was shut down on me, despite the fact that I had it listed. The developers were responsive via email more than once, but until they actually FIX the white list, I wouldn't use this app. FWIW, I really hope they get it fixed as I really like how this app is supposed to work.
