Speedx 3D: Nauseous Nancy's Need Not Apply
Anybody can race on the FLAT GROUND. How many can handle 3D hyperspace? SpeedX is a crazy, fast, intense accelerometer fueled ride through trippy tunnels with obstacles that are both static and moving.
You're glued to the surface and have the ability to go 360 degrees around the inside of a constantly morphing tunnel, avoiding objects and picking up "invincibility" powerups. Sometimes the tunnel will split and open up to a flat plane while you're flying through it. Sometimes, the flat plane will close on itself the opposite way to make you ride on the outside of the tunnel. It's constantly changing with the addition of random moments of blackout (no warning when objects are in your path) and gravity well (everything seems closer than it appears). Hit too many obstacles and you're done. Highest score wins. As far as I know, there's no way to win this game, it's just a matter of time till you crash and burn.
Options are sparse but don't need to be, just some simple gameplay and sound options.
There are online score leaderboards so you can see how horrible you are:
This game made my mother want to puke. Enough said, got get it!
