Android 4.4.4 has killed my phones capability to use the Spigen Slim Armor View case. The S view window does not work at all. When I close the case it briefly shows the sWindow menu through the screen and then it disappears and goes to my normal phone while the S view cover is over the phone.
I was thinking about totally resetting my phone, however, I have read on other forums that other individuals are having the same problem with no avail. fixing it. Does anyone know if there is a fix for this? It was an expensive case and I bought it for the S window feature that is now essentially not functioning. I tried taking the case on and off and resetting my phone, of which neither worked. I had also looked at the settings to make sure there was nothing interfering with the S window capabilities and there is nothing that I can see that is.
Is anyone still having this same issue? Any ideas of how to fix this?
