Root [Sprint/Cricket] Galaxy s 3 camera red line issues
Anyways I'm having my galaxy for almost 5 months never had an issue with my phone but today I noticed when I was using the camera that when the flash is on it makes the picture come out really red and blue thin stripes on the pic, now does anyone have or had these kinda issues before plz plz reply and help a brother out thanks much
:confused:
Anyways I'm having my galaxy for almost 5 months never had an issue with my phone but today I noticed when I was using the camera that when the flash is on it makes the picture come out really red and blue thin stripes on the pic, now does anyone have or had these kinda issues before plz plz reply and help a brother out thanks much :confused:
before factory reset, i would try going to settings > application manager > all > camera and clearing data and/or cache.
Did you resolve this red line issue? Our S3 camera is doing the same thing. I tried a different camera app, same problem. I cleared camera data, same problem.
Randy
My sisters phone just started doing this the other night. I believe it was in photos with flash being used, but it didn't happen on all of them.
She is running stock OTA, L710VPUCMK3 Android 4.3.
I would really like an answer to the cause as well, even if it can't be fixed.
I was going to root her phone, if for no other reason than her ridiculously poor battery life, but I might do it sooner if it could fix this issue.
Thanks in advance.
Are u using hdr? That did it for me when it tried to stabilize the image. Try turning off HDR and reboot. This fixed it for me about a month or two ago... never looked back. There are other camera apks that are supposed to enhance your camera. Maybe they could solve it fer ya... I'm looking for a working link. I'll test for stability and report back to ya all.
I was having the same problem with my S3. I reseted the camera to default settings and it seemed to fix it. While in camera mode, press the gear icon (for settings), scroll down to reset.
I work at a Sprint service center, and I ran into an S3 with this problem today.
Fixes seem to be hit or miss, but here is what I have done to try and fix the problem:
Reset the camera app via the camera settings
Reset the camera app via the phone settings and cleared cache
Replaced camera
Replaced the LED flash via surface mount
Tried with a different backhousing and camera/LED lens cover
The problem is still occurring. The only thing I haven't tried to this point is a factory data reset. I will probably do that as well, but I need to wait for the customer's consent. But at this point I am fairly confident that a reset will not fix the problem either.
My guess is the problem lies in the software/board of the phone with the image proccessing. For those who have found a fix with resetting the camera, I would guess that it was just luck, because I don't think the problem has anything to do with any settings.
has anyone found a solution yet? Ive also been having this problem and tried almost all the possible solutions.
i am pretty sure that it is not a hardware issue.. my wife is using samsung s3 and suddenly experience this same issue. it only happens when flash is on, but no flash and no red line issue.
i tried to use different apps that uses camera like IG or facebook and etc.., i used the camera inside those apps with flash on, all pictures are perfect.
meaning the built-in camera apps has been corrupted by a lot of apps that has permission to use it.
i am not sure yet which one is the culprit app, but i will look for it and will keep you posted.
try it also guys so we can isolate this issue.
(factory reset will easily solve this)
