Root [Sprint/Cricket] Missing storage issue 4.3(solved)
DaisFlaque
Android Expert
So I thought I'd let everyone know I had a really weird issue with my internal partition of my sgs3 or d2spr, I'm running PAC-man rom and it's 4.3 (with correct gapps) and I went through the setup process just fine, untill it went to auto install my old apps. It hit me with not enough space. I was perplexed as to why I hadn't enough space. So I went through the typical trouble shooting es FE/Root Browser and delete... Right?? NOPE!
I plugged it into the old PC and found it too saw over 10GB used and less than 1 left. so I went through and killed everything and it was still full. Well I've tried everything "Let's Google it" is my words. NOPE! nothing... So here I was no storage left and (Oh by the was at this point I had re-flashed three times. CLEAN not dirty. Factory/Cache/system/davlic/everything two times.) Only room for a few apps. ..
I found a fix. Backup everything to PC or removable storage. Reboot recovery/mounts and storage/format internal (or sdcard {NOT EXTERNAL} ) reboot and I, as you should be, fine.
yes, when you install an aokp rom, itll move all of youre previous stuff to a root folder on your internal sd card called "0", wiping the internal sd storage would rectify that
Yes but it was bloated with files I could not access. Or see." I plugged it into the old PC and found it too saw over 10GB used and less than 1 left. so I went through and killed everything and it was still full."
there is a repartitioning that goes on in 4.2 and 4.3. to get back from 4.3 you may need to odin a stock rom to repartition. than you can flash as always
Didn't have a problem. Just wiped and flashed. From PA to stock and from there to cm10.1/cm10.2 and so on. Thx for the tip though.
