DaisFlaque
Android Expert
I've flashed and installed and wiped and everything. Has anyone got this to work?
O ok that make some sense . Once you flash the apk clear the apk data and scroll to google framework apk and clear data and cache . Both of these can be done from the manage apps . Setting>application>manageapps . Google playstore apk .and google framework apk clear app data and cache . Then power off and back on .That should work post back if it doesn't
