Root [Sprint/Cricket] Unroot directly from Superuser?
jackroo
While I was browsing through Superuser I noticed that there is an option to fully unroot. If one were to go through this process would anything on the phone mess up? Just curious. Thanks
probably not, but why would you unroot? you must be insane lol jk... but seriously why would you even think about unrooting? you have full control of your phone and all its abilities. why would you let that go?
I'm not at all thinking about unrooting! :)
I just happened to see that option and thought it was a bit odd
no, you would need to unroot via Odin. If you rooted, then unrooting is a really similar process, which im sure youd be able to do. If you have any questions, feel free to ask
No, once you go through the Superuser options and click fully unroot, you need to use a browser like Astro or es file explorer and remove /system/bin/su, or /system/xbin/su, and then remove /system/app/Superuser.apk. Reboot and enjoy.
Hit Thanks if this helped you! :D
Hi guys, I forgot about this thread. I am still rooted and plan on staying rooted on my future phones :) I just happened to see that little option under Superuser. Thanks!
