How do you do it??Have you done the factory reset yet?
My phone was fine after the update, until I noticed the theme was stuck. I tried many things to clear it but only the factory reset succeeded.
OK... thanksSettings - backup and reset - factory data reset.
OK... thanks
ThanksDon't forget smart switch and helium for your backups. I also recommend copying your storage to your pc, since smart switch corrupted some of my boxing videos when it restored.
Battery Saver,AKA Cheetah Mobile=GARBAGE.It was the new "battery saver"
No... I mean the one on the phone after the update!Battery Saver,AKA Cheetah Mobile=GARBAGE.
Do yourself a huge favor,fork up $1.95 for Package Disabler Pro & disable all the Crapware associated with the battery saver & any Sprint "Diagnostic" crud & other Sprint items that you do not use.
It's likely the same garbage,just in a different wrapper.......No... I mean the one on the phone after the update!
And you have always been right so far!! Its off!!It's likely the same garbage,just in a different wrapper.......
Either way,my recommendation stands.
I still have the NOTE 5,although in the Lollipop variety (THX T-MobileAnd you have always been right so far!! Its off!!
