Help Starting to get mad...
cybermunk
Well sitting here and trying to run SOC, but my Ideos S7 won't be recognized on my Pc.
I have tried to install the drivers from Huawei Devices site, but no luck. Have tried to reinstall the drivers but no luck.
Any hints for a fellow braindead geek?
I had the same problem with my S7 and LG Thrive. I purchased a new cable and no long had any problems with connecting.
Cable I purchased.
Newegg Item=N82E16812119354
~Doug
i could not get my s7 to get recognized as well,
until i did the following
1) i got the UPDATED(most recent) 2.2 from huawei website.
then
2) Download the official drivers and installed but no success.
then
3) i rooted my s7
it was at the beginning of rooting(Super One click 2.3.3) that I could not get my s7-104 "connected". I had tried prior versions of Super One Click with no success. But when using 2.3.3, SOC could not "connect", it kept coming back with "Abort, Retry or Ignore". Of course I would click "Abort"
when it first appeared(On step 3), but i was getting frustrated and selected "Ignore" on my next attempt. It was then the SOC asked me if I wanted to use it's on DRIVERS. I selected yes. And it took.
SOC then continued through the remainder of the STEPS(3 - 5).
I repeated SOC again and it completed with no STEP failures.
here is my SOC "successful" log
--------> START OF LOG FILE
* daemon not running. starting it now on port 5037 *
* daemon started successfully *
$ export PS1=""
getprop ro.build.version.release > /data/local/tmp/output 2>&1
export TEMPRANDOM=71252
export PS1=END:$TEMPRANDOM;cat /data/local/tmp/output
2.2.2
END:71252export PS1=""
getprop ro.product.manufacturer > /data/local/tmp/output 2>&1
export TEMPRANDOM=55780
HUAWEI
END:55780export PS1=""
getprop ro.product.model > /data/local/tmp/output 2>&1
export TEMPRANDOM=57649
IDEOS S7
END:57649export PS1=""
getprop ro.build.version.incremental > /data/local/tmp/output 2>&1
export TEMPRANDOM=90391
hid.20110324.061105
END:90391export PS1=""
ls -l /system/xbin/su > /data/local/tmp/output 2>&1
export TEMPRANDOM=92927
/system/xbin/su: No such file or directory
END:92927export PS1=""
ls -l /system/bin/su > /data/local/tmp/output 2>&1
export TEMPRANDOM=23560
/system/bin/su: No such file or directory
END:23560export PS1=""
-------> END OF LOG
