daniellouwrens
Hi
how do I set up a startup PIN that has to be entered each time my phone is started.
Thanks
Daniel
Thanks
Daniel
Hi. I did not want to enter a pin after every lock screen, only when the phone is switched on. Is that possible?. It used to be with my galaxy ace. Cheers.. DanielSettings > Lock Screen > Screen Lock - From there you can opt to unlock with a PIN.
Thanks, but I am having a problem, when I select Setup Sim Card Lock it asks for a PIN but I haven't set oneYou could set up a PIN for your SIM, so you will be prompted for that whenever the phone is restarted. Settings/Security/Setup Sim Card Lock.
up yet....
What am I missing?
Cheers
Daniel
