nabu
I've had this phone almost one year...then since last month, its original battery drains like mad and I've tried some power saving apps, turned off gps/wifi/sync without obvious improvement.
I have to suspected it a bad battery, but i didn't have any replacement to test. My friend told me another way that removed the stock battery and spined it on a flat table. If the battery spined for long times it must be bulging. Guess what? I waited over ten seconds untill it stopped! Now I have to wait the new battery orderd from mpj arrives home...Sooo if any already tried fixing your battery life issue on software side, try this way and test whether you should buy a replacement.
