stop iTunes top podcast player
craigb515
I have an S5 and daily the iTunes top podcast player will download to my phone. Cannot locate it as an app, and need to go to "Storage" to delete. Chews up 5+GB of memory. Any way to stop this from downloading?
Hi @craigb515, and welcome to AF :)
Do you by any chance have the Podcast Republic app installed? Just a hunch. :D
Are you getting a notification that the player has downloaded? If you long-press on the notification entry and choose "More Info", what do you see?
I do have podcast republic, thought they might be associated. Do not get a download notice, only notice that storage space is running low. When I check the Misc files t shows, usually 4-5gb
I'm not familiar with that piece of software, but it did come up when I was searching for "iTunes top podcast player". Does it have any settings that might adjust what and when it downloads, as well as how long those downloads stick around?
