Android 8.1.0 and Messages 3.9.039 on Moto G5+. Cannot find a way to stop Messages from vibrating on incoming text. Also Vibrate on Tap does not Thanks for any help.
Open messages and then tap on the menu (three dots, upper right) and go to settings>notification and turn off "sound with vibration". It should only play the assigned ringtone after that.
Vibration when you tap is actually under the general settings on the sound menu. (settings>sound>vibrate on tap) You'll also find vibration settings under the keyboard option in case you want to have vibration when you type.
