Help storage usage does not add up
  • Thread starter Thread starter polymachine
  • Start date Start date
P
polymachine
Guest
Hi there,
I've got an HTC Desire 700 and a bit of a dilemma with my internal storage.
The storage information in the settings menu gives the following info:
7.28 / 8 gb used
Apps and music are just under 2 each and other has over 3.5.
The thing is that both adtro and ES file managers show a root folder size of just over 4 gb.
Where do the additional 3 gb (presumably the other section) come from?
manual searching found no obvious huge folders.
Help please!
Please check out the two posts here carefully and please try both apps -
http://androidforums.com/threads/qu...e-is-your-storage-truth-read-me-first.906249/
Your Desire 700 has 8 GB of storage - but before it can be a smartphone, it has to be a phone.
There are many hidden storage areas with firmware to make that happen.
The DiskUsage app in post 2 there will give you a list so you can appreciate how deeply the phone technology goes.
Otherwise, it really a good user storage surfer.
The first app, Storage Truth, is what you care about for storage you can use for apps, app updates and private data.
In the first post I explain why the confusion exists with others tools. I know because I've been in your shoes with the same questions before myself.
Storage Truth tells you about the hidden size allocations that ES File Explorer can't unless you're rooted - and even then assumes that you know what Storage Truth can tell you. It's not a friendly situation for understanding at all, that's why we built Storage Truth.
Let me know if that helps!
