Strange Edge app
AcsPrime
Hey guys,
I am not sure what kind of application I installed but it seems something has installed it self as an edge app:
You can see the normal edge thing there too.
When I slide it opens this app with a bunch of videos.
I have no idea what I installed that might have installed this too.
How can I find out what app this is so that I can remove this??
Trouble is that there are quite a few apps that provide such functionality. If you can activate it you might be able to work it out. Otherwise go through your apps and look for anything new, anything with shortcut or panel in the name.
Sure but the thing is I haven't installed anything that should provide this functionality.
The last apps I installed were:
- Google calendar
- Authenticator
- QR Code Reader
- Translate
These are the ones I remember installing in these past months. None of them is suppose to offer this
Ok, I think I found the app. It was the QR Code reader. Not sure how the heck that happened but I went to the app and cleared the data and the overlay thing is gone.
Thanks for all your help.
