Strange icon in top bar pls help
Junco
The one by the alarm. No idea what it could be. No notifications or anything related to it either. No harm done, apparently. But still I'd like to know.
I have Android 9 and EMUI 9.1 if that helps.
Thanks a lot.
NFC, i.e. "Near Field Communication", is turned on.
If you are using a phone payment system, or one of those features that allows you to share media between 2 (very) nearby devices, then NFC is what they use. It can also be used for authentication (e.g. unlocking doors), and various other tasks. If you don't do any of that stuff (I don't myself) then you can turn it off and the icon will go away.
Never used NFC so I would have never guess. Thanks a lot man :)
