Hello svim, thank you for your reply ; when I was clicking on notification bar to see what is this icon I didn't find any of the list in notification menu with matches this icon and also I went to installed apps menu non of them has this icon even I went to system apps and nothing has this icon , finally I tried the way you mentioned for widgets, after long press I choose widgets but then in the list there is no settings option to add a a widget, what should I do now? I am really worried about this icon that it can be some kind of hack specially that this is my first android phone which I use after using iPhone for long years .
