Help strange prob with my x10
tlo
Ok guys i have noticed when i take my x10 out of my pocket the phone has opened loads of the apps i have on it ie games,browser even the ebay app.It has even rang my daughter.Being as you have to press the button at the top and then swipe the screen i do not know how it is doing this can you help as i dont want to get rid of it.Thanks for looking
To turn on the screen, the top button isn't the only one that turns on the screen.
So does the middle button on the front.
Either change pockets or download a lock app (probably one that doesn't require root....unless you have rooted your phone)
https://market.android.com/search?q=lock&c=apps
Or get a carrying case. Or even a rubber case that helps hide the buttons on the front a little better.
  • Like
Reactions: tlo
Thanks for the advice i have downloaded one of the apps lets hope that dose the trick.It was rooted but i dont think it is now as i have had to do reinstall the os
