Strange stutter on a Web page
doc1964
Hi there, wondering if anyone has experienced this issue. When i access this one web site,
www.live-footballontv.com
it takes forever to scroll up or down the page. It is very stuttery.
I just assumed it was some kind of coding issue so have persevered with it.
Anyway didn't have my phone to hand tonight so used my wife's s7 to look at this same page and it worked perfectly. Could swipe my finger up or down and page scrolled smoothly.
It only seems to happen on this one page, anyone any idea why it should work so poorly on the s8 as opposed to the s7. Both phones running Chrome. Thanks for any ideas.
Can i ask, has anyone with an S8 tried looking the same page, is it flakey with you. I have checked the chrome settings on my S8 and wifes S7 and they seem to be the same. Curious if it does this with all S8's or is it something amiss with mine. Thank you.
Sorry, tried the site with Chrome and Brave browsers and the site works smooth and fast on my S8+
Thank you for that, time to try resetting chrome and phone if necessary.
Thanks again, really appreciate it.
Enjoy your weekend.
Well, after a bit more hunting about on line, i found someone mentioning lag etc. and said it was caused by a password manager they used (last pass) with a setting in accessibility.
Well, i happen to use True key to manage all of my passwords so looked in accessibility settings and there was a setting there allowing one touch sign in using True key.
I switched it off and went back to the web page and it works perfectly, infinite scrolling when you flick your finger on screen. I have absolutely no idea why this would interfere with this one web page as it is not even one that i log in to.
My issue is fixed but it bugged me not knowing why this particular setting would cause such an issue. Anyway, quick google search for "password manager, accessibility and lag" found the following page that explains the reason for it.
Thanks again to all for their input.
https://www.xda-developers.com/andr...g-lag-issue-with-password-managers/?nocache=1
Glad you got it fixed and thanks for posting the resolution for others to read that may have the same problem. :)
I'm also glad you got that fixed but you got to keep in mind that some sites is not Mobile Friendly and most likely better accessible from a PC or laptop source.
