elbmek
I keep getting texts from 'CB' with the 0121 in it and nothing more with the symbol of a radio mast - what the hell is it and how do I stop it? Vodaphone do not have a clue?
Its OK - I found this:
Go to your messaging, press the menu button to bring up the options, click on settings, then scroll/slide down about 2/3 of the page of the different options and you'll see an option for receiving CB messages. It's Cell Broadcasting messages - basically for testing purposes. Make sure the check mark is off. If the check mark is on, you'll receive Cell Broadcasts.
Strange thing is, I never checked it in the first place.
