streaming audio channels
avispi
hello.
I need to be able to broadcast 6 audio channels over LAN (wirelesly via router).
then the option to play audio at multipile ports of the LAN.
I rather have the 6 channels broadcasted from one system (computer, tablet phone) but if I have to dedicate a separate system to broadcast each channel it's ok.
the broadcasting systems can be of any kind but the receiveing are android systems.
at the receiving points I have the 6 (ip possibly?) channels to be preset with some nice graphic interface so I don't have to type in the ip adress every time I want to switch a channel but have the channels numbered and choosed by number buttons or a "channel plus" and "channel minus" buttons etc.
that also means the broadcast should always be to the same ip adresses.
is it possible?
does someone know an existing software that provides such solution?
