Root stuck at Lg logo please help
blazebluu
i recently just flashed the simplicity xl rom and i forgot to wipe data,cache and dalvik now my phone wont get passed the lg screen some help me please
I'm having the same problem. I can't get to cwm. "adb reboot recovery" is not working. I can only get the phone in fastboot mode...
Please halp
Please halp
you should do the last part because people have been somehow unable to restore download mode.
You will know that it is restored when download mode looks different next time you boot into it.
After restoring the laf partition, you should be able to run:
Code:
fastboot continue
and it should boot into download mode.
If it shows an error, reboot into fastboot again, run:
Code:
fastboot erase laf
fastboot flash laf laf.img
fastboot continue
if it still doesn't work post here please.
now u can unbrick with LG Flash Tool or look at the twogbsd's simple unbrick guide.
Code:
fastboot continue
Code:
fastboot erase laf
fastboot continue
When Irun these commands it just says waiting on device and gets stuck.
Turn your phone off.. Hold the power button and vol - at the same time.. When the logo dims let go about 2 seconds then press the same buttons it should take you to the restore menu.. Hit yes until you're in recovery..
i tried that but it shows it. and it just flash the logo then cuts
When I type these commands:
fastboot erase laf
fastboot continue
This is the screen I get and it is stuck here forever. (yes, laf.img is in the directory)
Ok never mind I figured it out.
The screen above is what you should see in order to use the LG Flash Tool to unbrick your phone!
I was not seeing this on all the attempts to restore my phone so apparently my phone was booting to fastboot but not to Download mode.
My phone appears to be totally restored and working perfectly after being bricked for over a month...
i only have fastboot mode and i did that thing to get back download mode but it wont let me access it. i really need to unbrick my phone please help me
What do you mean "it won't let me access it"?
Did you get to the same screen as in my screenshot??
ok im having the same exact problem, when I restore my LAF it doesnt go back to the firmware download screen it shows errors. Is there a stock laf.img file i can download? My backup must be corrupt
I got the original laf file, now it says secure boot error when trying to access download mode, then goes to a black screen and my computer recongnizes it. I dont know what to do from here
Virgin Mobile LG Volt LS740P stuck in fastboot after download flashing with stock rom multiple times because it keeps getting suck in boot loop. Boot loop starts after Google updates? Leaning how to flash with fastboot.
